Thread started 17 Jul 2010 (Saturday) 12:16
Shooting info question
vrsixer
Jul 17, 2010 12:16 |  #1
I just took samples using a Canon 24-105L with my 1D2 and in both DPP and LR2 it shows in lens info only as 24-105mm. Before it used to say EF24-105mmf/4L IS USM on my 40D. Just wondering why?
Is it inherent to the body? My 17-40L on my 30D still shows EF17-40mmf/4L USM.
Canon ­ Bob
Jul 17, 2010 12:40 |  #2
It's simply down to the way that the body adds the data to the file. The lens (24-105 in your case) has a specific id which is recognised by the body and then decoded. The 24-105 is Canon id #237 but different bodies may well have a slightly different text string to tie up with it.....maybe later bodies are more specific because there is more memory available to allocate to the look up table.
Bob
1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
vrsixer
Jul 17, 2010 13:05 |  #3
It's weird cause if I use a 3rd party exif viewer, it gives the lens type as Canon EF 24-105mm f/4L IS. I just thought metadata would be the same if the info is available.
I just realized it's the same with my 70-200L and 1D2. It must be the body.
1,086 views & 0 likes for this thread
Latest registered member is makgun
677 guests, 263 members online
