Thread started 19 Jul 2010 (Monday) 13:34
7D AF setting question:
jacobsen1
Jul 19, 2010 13:34 |  #1
when I want the camera to track something across the frame, what settings do I need in terms of AF point selection and how it'll then hand it off to the points across the frame as the subject moves? I know I need AIservo. My example is with a static framing of a scene, but where something is moving across the frame. I DO NOT want to just use the same point.
My Gear List
my sites:
benjacobsenphoto.com (external link) | newschoolofphotography​.com (external link)
GND buyers FAQ
FOR SALE: 5Dii RRS L-bracket, 430II, 12mm macro tube PM ME!
yourdoinitwrong
Jul 19, 2010 13:39 |  #2
The examples I have seen used Auto AF (all points) or Zone AF. I have not done it myself but I believe in the B&H videos they demonstrated this with a runner.
5D4 w/BG-E20, 24-105 f/4L, 70-200 f/2.8L IS II, 35 f/1.4L, 85 f/1.8, 100 f/2.8L IS Macro, Sigma 50 f/1.4
Full List
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jul 19, 2010 13:47 |  #3
With the 1 series, when using AI servo and all 45 AF points, the hand off to other af points only occurs after the initial focus lock from the center AF point is made on the subject.
I say this only as I am not sure if you are hoping the camera can AF and lock on a moving subject coming in from one side of the frame and then moving off to the other side, without any panning. You will not get the initial AF lock on a subject that is not under the center AF point to begin with.
You can force it to start with an off ceter AF point, but to do this you can't use all 45 points, you need to specify the off center point for initial AF, and then use custom functions to allow "expansion" to neighboring AF points> With Expansion, you can use any AF point as the initial point, however this limits you to only a few AF points for the hand off, not all 45, so again, not clear across the screen.
I assume this holds true even with the 7D's new AF features.
CDS' HOT LINKS
jacobsen1
Jul 19, 2010 14:22 |  #4
I want it to start with a specified point though (top point in vertical) and follow the action through the frame though. Straight line down the frame, but the subject is coming closer...
For this example, it's my kid coming down a slide! :lol:
My Gear List
my sites:
GND buyers FAQ
jwcdds
Gallery: 1929 photos
Best ofs: 8
Joined Aug 2004
Jul 19, 2010 14:25 |  #5
I haven't had any personal experience with this but according to the B&H video tutorial, you set it up as all-point (19) focus, but you can still setup the starting point to acquire focus. At least that's the way I remembered it on the tutorial video.
I just tried it out at home, instead of having a moving object, i just panned the camera. Yep. set it up as 19-af, ai servo, and you can select the starting point to acquire/lock focus and then then points will go along as you move.
Julian
Ok_Student3368
Jul 19, 2010 14:32 |  #6
On the 7D you can use the auto AF points, but you can also select a starting point. The 7D changes everything. You do NOT have to start from the center point like with a Rebel or 5D. You can start off center if you wish. Start there, and it'll track your subject moving. I played around with it a bit last week. I'm not sure how well it works in practice, but I'm sure it'll work.
I pretty much did what the above poster said and it worked fine (just panning in my room).
apersson850
Obviously it's a good thing
Gallery: 35 photos
Jul 19, 2010 14:57 |  #7
CyberDyneSystems wrote in post #10565091 (external link)
No, it doesn't, neither with the 7D nor with the 1D Mark IV. They both allow you to use all points and start with any you like. But the 1D Mark IV doesn't track with all points, but with a "cloud" of 18 points surrounding the currently active point. When handing over, the cloud moves along with the current point, so it's effectively like using all points.
This is probably to avoid overloading the AF processor, and implies that the 1D Mark IV does the same job as the 7D in this case, since the 7D always has 19 AF points.
Anders
jacobsen1
Jul 19, 2010 15:45 as a reply to  @ apersson850's post |  #8
jwcdds wrote in post #10565337 (external link)
OK, how'd you set it up specifically?
servo I got, but do you turn on all 19 points or one to start? And is there a setting to tell it to hand off to others or what?
Thanks Julian.
My Gear List
my sites:
GND buyers FAQ
jwcdds
Best ofs: 8
Joined Aug 2004
Jul 19, 2010 15:50 |  #9
I don't think there's any other menu options that you need to turn on. What I did was:
Switch AF to AI Servo. Then switched the mode to All-point. During this time, I see the entire AF frame light-up with the brackets (showing me that all-point is selected), but at the same time, there was 1 square that was also visible.
From that point on, I just half-press my shutter button and that frees up the single point and I moved it where I wanted it to be with the little thumb-joystick. And then from that moment on, that will always be the starting point of my AF-servo tracking. (until you decide to change the starting point with the joystick button again)
Julian
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jul 19, 2010 17:22 |  #10
dmo580 wrote in post #10565377 (external link)
On the 7D you can use the auto AF points, but you can also select a starting point. The 7D changes everything. ....
Cool!
CDS' HOT LINKS
jacobsen1
Jul 21, 2010 06:08 |  #11
jwcdds wrote in post #10565826 (external link)
yeah, I tried it yesterday w/o checking back and that's exactly how I got it to work too, it then tracked it across the frame.
So then how do you get it to pick points from all 19 again then? Halfpress again then just don't touch the joystick? (yeah yeah, trying this would answer the question ;)).
My Gear List
my sites:
GND buyers FAQ
oldvultureface
Gallery: 85 photos
Jul 21, 2010 06:27 |  #12
jacobsen1 wrote in post #10575852 (external link)
Switch to one shot. All 19 will then be active again for closest/most contrast focusing.
Reevo
Jul 21, 2010 06:41 |  #13
just wondering, what are you trying to shoot?
My Blog (external link) // Canon 5D, Canon 7D, 17-40mm f/4L, 24-70mm f/2.8L, 70-200mm f/2.8 IS II USM, Sigma 50mm f/1.4, 580EXII, 430EXII, cybersyncs
hollis_f
Jul 21, 2010 08:34 |  #14
Reevo wrote in post #10575941 (external link)
Er....
jacobsen1 wrote in post #10565313 (external link)
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
robfoto
Jul 21, 2010 09:47 as a reply to  @ hollis_f's post |  #15
gary luhm provides an excellent, detailed tutorial about AI Servo Focus at his site: http://garyluhm.net/bi​o/tips_0310.html (external link)
robfoto
Canon 7D Gripped (BG-E7), EF 16-35 L II USM 2.8, EF 28-135 IS USM, 580EX II
2,853 views & 0 likes for this thread, 10 members have posted to it.
992 guests, 107 members online
