I'm thinking about picking one of these up (they're the cheapest ones) and I was wondering if its a good starter bulb?
Mike787 Member 222 posts Joined Dec 2009 More info | Jul 19, 2010 18:00 | #1 I'm thinking about picking one of these up (they're the cheapest ones) and I was wondering if its a good starter bulb? Canon EOS 1000D | Sigma 70-200mm f/2.8 EX DG II | EF 50mm f/1.8 II | EF-S 18-55mm IS f/3.5-5.6
forzabrian Member 65 posts Joined Jun 2010 More info | Jul 19, 2010 18:12 | #2 How much can you get one for? What body do you have?
Jul 19, 2010 18:17 | #3 I saw them on ebay for 30$. I have an XS and am prepared to pick up the remote trigger as well. I'm just wondering which strobe I should go for. Canon EOS 1000D | Sigma 70-200mm f/2.8 EX DG II | EF 50mm f/1.8 II | EF-S 18-55mm IS f/3.5-5.6
rhys216 Goldmember 1,814 posts Joined Mar 2010 Location: Oxfordshire More info | Jul 19, 2010 19:05 | #4 Permanent banThey are very good, get the 460II version though.
Jul 19, 2010 19:42 | #5 I've never used manual ocf or lighting before, would the 460 cause me to run into problems? I'm trying to keep costs as low as possible so if the 460 will suit me I'd like to go with that. Canon EOS 1000D | Sigma 70-200mm f/2.8 EX DG II | EF 50mm f/1.8 II | EF-S 18-55mm IS f/3.5-5.6
rhys216 Goldmember 1,814 posts Joined Mar 2010 Location: Oxfordshire More info | Jul 19, 2010 20:46 | #6 Permanent banYou won't find anything better for the money...
malow Member 169 posts Likes: 2 Joined May 2009 Location: Brazil More info | its is good, but if you pretend to do shooting on outside, you may want a stronger flash, like the yn-460 mk2 to be able to "compete" with the sun mods: http://www.flickr.com/photos/malow/
CraiginLA Member 133 posts Joined Apr 2010 Location: Alexandria, Louisiana More info | Permanent banAre you absolutely certain that you do not want E-TTL? While the previous comments have correctly indicated that the YN-460 is a capable budget-priced flash, it is fully manual. This is fine for situations where you have the time to determine what flash intensity to use to suit your desired aperture setting/ISO combination, but it will not suit your needs if you will be shooting in a rapidly changing environment where you need the flash to automatically adjust its output by metering a preflash. --- Craig ---
watt100 Cream of the Crop 14,021 posts Likes: 34 Joined Jun 2008 More info | Jul 20, 2010 05:07 | #9 Mike787 wrote in post #10567091 I've never used manual ocf or lighting before, would the 460 cause me to run into problems? I'm trying to keep costs as low as possible so if the 460 will suit me I'd like to go with that. the YN460 is a good beginner flash with full manual controls and optical slave but you might want to consider an ETTL model that also has manual controls like the YN465 - (less than $70) or maybe the YN-467
Jardiniboy Senior Member 508 posts Joined Jan 2008 Location: Waipahu, Hawaii More info | Jul 20, 2010 05:22 | #10 |
Jul 20, 2010 07:17 | #11 Ok thanks guys I'll take that under consideration before I dive in. Canon EOS 1000D | Sigma 70-200mm f/2.8 EX DG II | EF 50mm f/1.8 II | EF-S 18-55mm IS f/3.5-5.6
Tubthumper Member 240 posts Joined Jan 2007 Location: Scotland (God's Country) More info | While we're on the subject, I may be in the market for a couple of these. Before I do, does anyone know if they work with Strobies wireless triggers? They don't fire my Sigma 500 DG ST, so I'm looking for something cheap and manual. Canon 30D
Tubthumper Member 240 posts Joined Jan 2007 Location: Scotland (God's Country) More info | Ah, stuff it! Just ordered one off Amazon, delivered for £40. If it works, I'll be getting another one, and making use of that rather nifty-sounding slave function. Canon 30D
| Latest registered member is ANebinger 927 guests, 150 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
