Thread started 19 Jul 2010 (Monday) 18:11
Metering with gnd filters
CameraBuff
Jul 19, 2010 18:11 |  #1
How is everyone metering when using gnd filters? I read an article recently that said to take your reading, lock it in and than insert the gnd to take full advantage. That did not seem right? I have also read to take the reading of the sky and than the foreground and subtract to get the filter strength but that is difficult when you are using a tripod, especially if it's low to the ground?
Sony A7r, Sony 16-35 f4, Canon 1d3, Canon 70-200 f4L, Sigma 150-600 contemporary, G1X, Lee filter holder and gnd's, Singh-Ray reverse gnd
jdizzle
Darth Noink
Jul 20, 2010 00:01 |  #2
CameraBuff wrote in post #10566653 (external link)
You should try LV. It makes inserting the GND a lot easier. I then go by the live historgram. It works well imo. :) I'm not sure if the 40D has LV. Does it?
HrcRacing
Jul 20, 2010 02:36 |  #3
jdizzle wrote in post #10568507 (external link)
Yes it does and I agree that that makes it much easier to use GND's.
Regarding metering, in LV you can move the white box around and provided you have at least the first bit of "INFO" on, you can depress the shutter half-way and see what the shutter speed will be. Could you meter the sky/ground with this to determine your GND needs? I thought so but I'll have to test it.
Robert
Canon 40D | Canon EOS Elan 7
CameraBuff
Jul 20, 2010 18:32 |  #4
Thanks guys; looks like I will be experimenting more with live view in the future instead of just bracketing.
argyle
Jul 21, 2010 06:46 as a reply to  @ CameraBuff's post |  #5
Eventually, you won't even have to mess around with determining exposures...you'll be able to judge pretty much by eye.
jdizzle
Darth Noink
Jul 21, 2010 08:02 |  #6
argyle wrote in post #10575953 (external link)
Plus one! When you shoot enough with these filters, you'll basically never have to think about it. :)
jdizzle
Darth Noink
Jul 22, 2010 21:48 |  #7
HrcRacing wrote in post #10569025 (external link)
With LV it makes it so much easier. If you intend to do some exposure blending, I would bracket your shots.
CameraBuff
Jul 24, 2010 11:30 |  #8
Thanks guys. I do like that live view for landscape shots; one major reason why I now want to save for a 5dII instead of a 5d.
georgebowman
Jul 31, 2010 03:52 |  #9
Great discussion. I intend to pick up a GND before a fall trip west to shoot the aspens in color. I had anticipated metering first, switching to manual and then inserting the GND. However, LV sounds like great advice. Unforutantly, my 50D eats up the batteries in the LV mode. Any advice to get around this?
My Gear: 7d, XTi, 17-55f2.8 EF-S, 70-200f4L, 28-135 Kit lens, 2-580EXii
My Flickr http://www.flickr.com/​photos/gtbowman (external link)
TheBurningCrown
Jul 31, 2010 04:19 |  #10
georgebowman wrote in post #10635901 (external link)
Bring more batteries or don't use live view ;).
If you know how much light the GND cuts back depending on where it's position, you can turn the camera to spot meter, meter where the GND will be placed in the frame and where the GND will have no effect, calculate the difference, and then go from there.
You don't NEED to use live view - it's just another helping hand if you don't want to go through the hassle above (which is personally what I would do).
-Dave
Gear List & Feedback
3,232 views & 0 likes for this thread, 6 members have posted to it.
913 guests, 110 members online
