Can someone tell why these 2 set screws are on the center post? Apparently the two pieces come apart but why?
Jul 20, 2010 17:43 | #1 Can someone tell why these 2 set screws are on the center post? Apparently the two pieces come apart but why?
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Jul 20, 2010 17:48 | #2 Ordinarily the end of the aluminum tube for the center column is the rubber cap, seen at the bottom. When mounting the extension, the rubber cap is removed, and the extension (with the male end piece) is inserted into the original center column tube. The extension is really a combination of aluminum outer tube + the male insert. Since the double-ended male insert truly is 'inserted into' both the original tube and the extension tube, you need two locking screws -- which is what you are asking about. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
So does my tripod have an extension or do they come this way?
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Jul 20, 2010 18:46 | #4 Is what is pictured what you took possession of? if so, it came with a center column extension (which most photographers would avoid the use of, due to instability when extended up!) You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
It was purchased used the way you see it. Any suggestions?
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Jul 21, 2010 00:15 | #6 Suggestions for what? You don't have to leave the extension mounted, you can remove it and mount the rubber cap on the bottom of the main center column piece, to lighten the load. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
| Latest registered member was a spammer, and banned as such! 2856 guests, 158 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
