Here's a new version of the same shot at 800x533
That looks much better. Something else you might consider is that there's no reason to sharpen that OOF background because, if you do have any noise in the image, you'll just be sharpening it too.
A few words on SHARPENING:
Photobucket kind of sucks, because even you don't have them resize your images on upload, they will still batch compress them later. My photos I upload are about 500kb and within 24 hours somehow end up about 120kb, every time.
Well, no, it doesn't IF you set the parameters right. From their support:
Before uploading your images to your Photobucket account, choose either a
display or file size that is equal to or larger than that of your images. You
can do this by clicking on the 'Uploading Options' link in your upload panel
and then on the radio button next to your preferred size. If an option is
grayed out, this means the option is not available for your Photobucket
account type. Selecting a size larger than your images will prevent further
resizing upon upload and help expedite the upload process. To make the changes
permanent, you must upload at least one image from the upload panel. This is
important for Pro users using FTP or anyone using the Windows XP Publisher. If
you choose to use the file size options, the file size of the original image
will take precedence over the the display size and any display size is
accepted as long as the file size is less than your choice in the 'Uploading
Options'.
I always click on the image to get the 100% size that I've uploaded, & then use that URL for display, & in 5 years I haven't seen your problem.
