I have the Canon 90mm T/S lens, and I like it a lot. Now I'm thinking of adding the 45mm, or the new 24mm, and I'm not sure which way to go.
I have the 17-40L and the 70-200 f4L, so I do have a gap between 40-70mm. That said, I have the 5D MKII and the 7D, and with the addition of a 1.4x teleconverter the 24mm would give me the ability to use the 24mm lens at 24, 34, 38 and 53mm, with the 2x adding even more options, although I'm not sure if image quality holds up when using this lens with the 2x.
I mostly do general wildlife/nature/landscape photography, but also like to photograph old barns, sheds, and even some city architecture. I would appreciate any advice before making a decision.
Thanks, Mary
http://photo.net/photos/MaryKonchar![]()
I will say that flair isn't too bad on the 17 but I definitely hear you on the inability to use filters which is why I picked up the 16-35 as well. Good luck and be sure to post up some shots with the new lens!
