kezug wrote in post #10593113
Nice shots...can you provide some tips on how to capture lighting?
Thank you.
Night time shots of lightening are relatively easy.
Use a remote shutter switch if you have one.
Set the camera on a tripod, and if your lens has Image Stabilization turn it off.
Set the focus on a distant object if you can, or just infinity.
Set the camera in (M)anual mode.
I use ISO 400, and sometimes 200
f stop at about f/8.
The lens I used was a EF28-135mm @ 28mm
Whatever lens you use, set it on the shortest focal length to cover more sky.
If you have a remote shutter switch you can set the exposure to Bulb and just hold the shutter open as long as you like until you know you have seen a lightening strike. Careful not to go too long if there is a lot of artificial lighting in the area.
Or you can set the exposure to a specific time. On these I set it to 20 seconds.
What not to do: Often when you see an approaching storm you will see lightening strikes all over the place throughout the storm. You will want to try and follow it. What I mean by this is, you will see lightening strike and quickly point your camera in that direction hoping for another. Then it will strike somewhere else and you move the camera to that area. This is why a short focal length lens is nice, it covers more area and you can just aim at one location and keep taking shot there. You will miss plenty, but you will also capture many. I usually miss the best ones between shots just after I release the shutter or right as I open it.
Daytime lightening shots are a little more difficult. You either need to have great timing and be very quick on the trigger. Or you can set your camera on high speed continuous shooting and shoot in bursts. Doing this will waist a lot of shots, but your chances are greater that you will capture some lightening. If it's not a strong thunderstorm with frequent lightening I usually don't attempt daytime lightening photography.
Either day or night, a tripod is, IMO, a necessity.
