Thread started 22 Jul 2010 (Thursday) 09:45
CP filter stuck on Zeiss 21mm Distagon ZE
sdipirro
Jul 22, 2010 09:45 |  #1
So I just received my 82mm B+W Kaesemann slim CP filter. I removed the B+W UV filter from the lens and screwed on the CP filter. While turning the outer ring of the CP filter, it's possible I tightened the filter on the lens even more as I was getting used to the feel and size of this new filter on the lens. Since this CP filter has no front threads and I can't use the lens cap, I wanted to take it off and put the UV filter back on the lens...only I couldn't get it off, and I tried for several minutes. I only used my bare hands, and I certainly didn't want to do anything to damage either the lens or the filter. Both are brand new. Any suggestions?
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
bkdc
Jul 22, 2010 09:48 |  #2
Just unscrew it. As long as you know which direction to turn it, you should be fine.
RF 24-70 f/4L IS | RF 24-70 f/2.8L IS | RF 70-200 f/2.8L IS | RF 50L | RF 85L | 600EX-RT x 3
DAMphyne
"the more I post, the less accurate..."
Joined Feb 2003
Jul 22, 2010 09:50 |  #3
Try 1 of those tools they use to open jars.
Unless it's been damaged, you are likely squeezing the filter into an oval.
David
Digital set me free
"Welcome Seeker! Now, don't feel alone here in the New Age, because there's a seeker born every minute.";)
www.damphyne.com (external link)
Todd ­ Lambert
I don't like titles
Jul 22, 2010 09:51 |  #4
Yeah, your lens is probably a goner... I'll buy it from you for scrap, just let me know. ;-)a
I'd look into gettng a filter wrench. They're cheap and work.
You can make your own with a large rubber band, too.
Lowner
"I'm the original idiot"
Jul 22, 2010 09:52 |  #5
All I can think of is to try and spread the grip around the filter by using one of those rubber strap tools that pensioners use to open jam jars!
You could also try the "sticky" rubber sheets sold for the same purpose. We use it ourselves, because my wife has arthritis and cannot grip things.
The fact that its a slim filter you are having a problem with makes me wonder whether its twisting out of shape slightly as you try to remove it.
Richard
denoir
Jul 22, 2010 10:18 |  #6
A couple of methods:
http://www.ehow.com …ve-stuck-lens-filter.html (external link)
Luka C.D| My photos (external link) | My videos (external link) | My Cameras & Lenses
sdipirro
Jul 22, 2010 14:15 |  #7
Thanks for all the suggestions (and the link). Good stuff to try. Guess I won't have to just toss the new Zeiss lens in the trash afterall! Phew!
luigis
Jul 22, 2010 14:37 |  #8
Grip is the key, use anything made from rubber to hold the filter and turn it should surrender. You can use rubber bands, gloves, etc.
www.luisargerich.com (external link)
Landscape Photography & Astrophotography
My Awesome Gear List
corndog ­ cabernet
Gallery: 74 photos
Jul 22, 2010 14:43 as a reply to  @ luigis's post |  #9
I'm curious why you have a polarizer on a 21mm lens to begin with. No sky in your images?
sdipirro
Jul 22, 2010 15:11 |  #10
I'm planning to do some landscape photography at the beach and ocean. I want good contrast and separation of sky from ocean water and the beach itself, especially when the sun is strong and there's a lot of glare.
corndog ­ cabernet
Gallery: 74 photos
Jul 22, 2010 15:37 as a reply to  @ sdipirro's post |  #11
Well, take some pics and tell us what you see. Because of the very wide angle, a polarizer will have strong light fall-off. For the application you mention, a gradient neutral density gel type filter will get you there.
But hey, you tell us how it works.
MOkoFOko
nut impotent and avoiding Geoff
Joined Jun 2010
Jul 22, 2010 17:04 |  #12
Lowner wrote in post #10582988 (external link)
Agree with said suggestion--it's how we open tight jars, and it requires a LOT less force.
My Gearlist
amfoto1
Jul 22, 2010 18:59 |  #13
If you can't find one of those jar opener "grips" that some others have suggested...
Get a rubber band and put it around the filter. That usually gives you enough extra grip to get the filter loose. I keep a few in my camera bag for just that reason.
Once off, use a candle and rub it on the filter's threads. Wipe off any extra, but leave a little wax behind, which should lubricate the threads and help keep it from sticking again.
Oh, and ditch the UV filter... It serves no purpose. ;) (Actually, I would possibly use one at the beach, to keep salt spray off the lens... But I normally don't keep UV filters on my lenses for "protection".)
If shooting sunsets, remove all filters... unless you want flare, ghosting and low contrast images.
nightcat
Jul 22, 2010 19:27 |  #14
amfoto1 wrote in post #10585872 (external link)
Best suggestion of all!
keitaro
Jul 22, 2010 20:04 |  #15
you can try using a rubber strap wrench, like this
My flickr (external link)
3,655 views & 0 likes for this thread, 12 members have posted to it.
1698 guests, 139 members online
