Thread started 22 Jul 2010 (Thursday) 10:19
Seeing a difference that isn't there?
Lowner
"I'm the original idiot"
Jul 22, 2010 10:19 |  #1
Continued from here: https://photography-on-the.net …p?p=10579011#po​st10579011
Very strange. I opened both images into Photoshop using the embedded profiles and there is still a slight difference, visible if I switch them left to right, top to bottom. Its similar to the difference I get between DPP and Photoshop, although possibly even more subtle.
I checked one skin colour in the same location (x/y coordinates) and get exactly the same RGB values from both. So why me and not others. Any ideas anyone?
Maybe this needs to be in a different thread Rene? It may not be fair to the OP to take this in a different direction.
Richard
René ­ Damkot
Jul 22, 2010 10:56 |  #2
Split off :)
If I read your post correct, you see the difference when you view the images side by side or above each othr?
Isn't that simply caused by (the viewing angle) of your screen?
Or it might be that your screens illumination isn't even.
In both cases, the difference in brightness would not be related to what image, but to what position on your screen. Easy to test.
If you want to really compare them, layer them in Photoshop, then switch on/off the top layer.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Lowner
Jul 22, 2010 11:25 as a reply to  @ René Damkot's post |  #3
Rene,
First, thanks for splitting it away.
I've tried Elies two images every which way, and looked at them from left and right (from up and down are more difficult!) and the difference is constant.
Strange it certainly is.
Richard
HankScorpio
Jul 22, 2010 12:10 |  #4
You're not alone. I see a difference too even though there is none. I noticed my inability to see two identical things because of my job, which in part involves reproducing artwork digitally that was originally produced manually and having the result be identical.
I often have to ask colleagues for a second opinion because I see slight difference where there is none. If things are ever so slightly different then that stands out a mile to me, whereas others miss it but I can draw two identical black squares, print them out and hang them in the controlled light box and see one as slightly grey or slightly taller.
I went to an optician because I thought it was my eyes and they said it was normal, it's just the way your brain processes information from two eyes. Some people see it, some people don't, some people see it but ignore it without knowing.
My collection of boxes with holes (external link)
EXIF semper intacta.
Gort! Klaatu barada nikto.
Stevekin
Jul 22, 2010 13:20 |  #5
A more accurate/easy way to tell if there are any differences is to layer them in Photoshop, but instead of switching visibility on/off, simply change the blend mode of the top layer to Difference.
If there is no difference (which there isn't) the result will be solid black.
My Flickr (external link)
http://www.flickr.com/​photos/stevekin/ (external link)
Lowner
Jul 22, 2010 14:58 as a reply to  @ Stevekin's post |  #6
Stevekin,
I've just done exactly as you suggested and you are right, its just a solid black. Yet when I go back to normal blending and turn the top layer on and off I can still tell, so something is carrying across. It's not random, I can tell precisely which one is which with 100% accuracy.
Hank, I've never noticed this before. I layer up and hand match my panoramas, so am fairly comfortable getting close colour matches although I use the RGB numbers to get precise.
Richard
René ­ Damkot
Jul 23, 2010 06:08 |  #7
Stevekin wrote in post #10584143 (external link)
Yep. And if there's a very small difference, it will be *almost* solid black: Very, very dark gray ;)
Lowner
Jul 23, 2010 10:10 |  #8
Rene,
Close enough to black I'd not be able to tell?
As you know, I have a DPP versus Photoshop difference that we have aired several times here, hence my digging into this in the hope it just might help me with that.
Richard
René ­ Damkot
Jul 23, 2010 11:16 |  #9
Lowner wrote in post #10589229 (external link)
Yeah.
To illustrate:
Downloaded one of the images, added a subtle curves adjustment (128 > 130). You can just see a difference.
Duplicated background layer. Top layer set to blend mode difference.
Looks "black"
Added another curves adjustment layer on top, to make the difference visible: (10 > 255)
IMAGE: http://img.skitch.com/20100723-f1itcq6pr6sadfygfdjd6n31c.jpg
2,040 views & 0 likes for this thread, 4 members have posted to it.
1099 guests, 120 members online
