Hello, so I have started coming across this issue more and more frequently. At first I thought it was just a bad photo or two, but now Ive realized that apples dropped the ball. It seems that almost any photo with a blown out area of highlights, next to a gradual drop off, gets posterized by apples raw processing. How ever when processed with any other software, the problem is non existent, and is almost impossible to duplicate with any standard form of color and exposure manipulation.
A picture is worth 1000 words, so heres an example. All are untouched by any exposure/contrast adjustments.
We can clearly see how severe the issue is in aperture. It may not be as noticable, but the problem also happens in finders preview function(easier to see in the source files below). The problem does not appear in other software with an standard adjustments, and likewise does not seem to go away with any adjustments in aperture. The closest thing Ive found to alerting the issue is under raw fine tuning, to adjust Hue and Hue Boost.
Im including the CR2 file so some one with lightroom and any other RAW software can post and compare the issue. Also some one with aperture can confirm the issue. Or potentially a solution to this mess. Any more information and suggestions are welcome. And especially aperture users trying to figure the problem out.
Higher res jpeg examples
Source CR2 file
