Hey everyone. I work for a concert venue, and wanted to see if I could do a 360 degree panoramic photo of the inside of the venue.
I tried it today, and here is what I did.
Set up a Tokina fisheye @ 10mm in portrait orientation on a manfrotto tripod/head. It is not a panoramic head, just a 3 way tilt head. I leveled the tripod, set exposure, and began shooting.
I took about 7 images and made sure there was plenty of overlap.
I repeated this process in landscape orientation, and repeated the process again in both orientations with a 17-55 IS @ 17mm.
When I went home and tried to use photomerge in CS4 (set it on automatic mode) I got garbage results. Photoshop only seemed to use about half to 3/4ths of the pictures I took, and just stuck the other ones on the side.
I seemed to get the best results with the 17mm in landscape orientation, but it was still awful -- clear seams, images not lined up, and not a 360 degree view.
What am I doing wrong here -- is it an equipment thing? I have seen people say you need a panoramic head, but I have also seen people say they have done this hand held. Do I need more overlap? Do I need different software?
I want to try again, so if anyone has any insights, it would be very helpful!
