Is white balance the only must do while your image is still in raw format or are there other things better done in raw before doing stuff in tiff?
domat Senior Member 485 posts Likes: 14 Joined Jun 2010 Location: New York More info | Jul 24, 2010 11:18 | #1 Is white balance the only must do while your image is still in raw format or are there other things better done in raw before doing stuff in tiff?
HankScorpio Goldmember 2,700 posts Likes: 1 Joined Aug 2007 Location: England, baby! More info | Jul 24, 2010 12:54 | #2 Well just for clarification, you can't do anything to the raw. All you do is set parameters for how the raw will be converted into an image as raw itself is not an image. To answer your question though, do as much as you can in your raw editor. Personally 99% of my images never leave the raw editor before they get printed or converted for upload. My collection of boxes with holes
windpig Chopped liver More info | Jul 24, 2010 12:56 | #3 HankScorpio wrote in post #10595400 Well just for clarification, you can't do anything to the raw. All you do is set parameters for how the raw will be converted into an image as raw itself is not an image. To answer your question though, do as much as you can in your raw editor. Personally 99% of my images never leave the raw editor before they get printed or converted for upload. I'm finding the same using ACR5.7 in CS4 Would you like to buy a vowel?
griptape Goldmember 2,037 posts Joined Feb 2007 Location: Home More info | Jul 24, 2010 13:12 | #4 I can process 99% of my images in a raw editor without them ever needing to see photoshop. RAW is RAW, you just set the parameters that you want the image processed with for print/viewing. RAW is for "developing" the image rather than letting the camera tell you how it thinks the image should be developed.
Jul 24, 2010 13:21 | #5 Thanks for the replies. Lets just redirect this a bit.
HankScorpio Goldmember 2,700 posts Likes: 1 Joined Aug 2007 Location: England, baby! More info | Jul 24, 2010 13:29 | #6 domat wrote in post #10595511 If you are going to use photoshop or a plug in what should you make sure you do while the image is still in raw format. That depends on what you plan to do to the image but again, do everything you can. Make sure the exposure is dead on, add any colour toning, get the contrast and clarity right. Don't sharpen though as that should be your last step. My collection of boxes with holes
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Jul 24, 2010 13:59 | #7 domat wrote in post #10595511 Thanks for the replies. Lets just redirect this a bit. If you are going to use photoshop or a plug in what should you make sure you do while the image is still in raw format. griptape so what do you consider the developing stage? can you be more specific? The one thing that cannot be done with a rendered (jpg, tif, psd) image is the recovery of partially clipped highlights. If they haven't been recovered in the RAW converter, they are gone forever. Elie / אלי
tonylong ...winded More info | Jul 24, 2010 17:40 | #8 In addition to what Elie says, I've read that it's important to get your blacks "right" with your Raw processor -- that, similar to highlights, you want to make sure you get your darker tones above what could be clipped. But I don't have the technical expertise to give details. Tony
ChasP505 "brain damaged old guy" 5,566 posts Likes: 1 Joined Dec 2006 Location: New Mexico, USA More info | Jul 24, 2010 18:22 | #9 Are you going to use Photoshop (and ACR)? If so, the Basic tab is just that... the basic adjustments you'll want to address. And it's set up in a logical order so you normally follow it from top to bottom (with exceptions). You don't have to adjust everything, of course, or anything if the photo is perfect. But the order of adjustments should help train you to make your raw adjustments with a structured, logical strategy. Chas P
FastFredy Member 168 posts Joined Jul 2010 More info | Jul 25, 2010 21:26 | #10 domat wrote in post #10595511 Thanks for the replies. Lets just redirect this a bit. If you are going to use photoshop or a plug in what should you make sure you do while the image is still in raw format. Adjust WB/tint, tone curve, vibrance/saturation, different color's luminance and saturation if desired, clarity, fill light. this all i do with lightroom 3. it is pointless to convert raw files using default settings because that is just one idea of image conversion settings.
Jul 25, 2010 21:41 | #11 Thanks for the info guys.
| Latest registered member is SteveeY 1211 guests, 168 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
