Made out of 3 RAW images.
Please C&C.
![]() | HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by FLICKR |
Jul 24, 2010 16:57 | #1 Made out of 3 RAW images.
Bunnies will rule the world!
crimsonblack Goldmember 2,052 posts Likes: 6 Joined Feb 2010 Location: Las Vegas, Nevada More info | Jul 25, 2010 14:57 | #2 Looks washed out and flat. | 7D Gripped | 28-135 f/3.5-4.6 | 50 f/1.8 || --- Sony F717 digital (infrared) --- Bunch of Film Stuff:- | Nikon & Nikkormat | 50/28/70-150/400 | B & J 4x5 large format | Mamiya C220 |
GaryMcDuffie Goldmember 3,022 posts Likes: 1 Joined Oct 2008 Location: Scottsbluff, NE USA More info | Jul 25, 2010 15:12 | #3 As said, lacks contrast. Gary
TGrundvig Goldmember 2,876 posts Likes: 3 Joined Oct 2009 Location: Colorado More info | Jul 25, 2010 15:16 | #4 It looks flat...and it looks like the light mode you used was a bit off. See how the front part of the tree is nice and bright? If you change the light mode setting you can shift that light. Also, I would adjust the strength to reduce the halos. Halos are more present when the strength slider is too high. There is also another slider...I think the light smoothing one....that can reduce the halos. Of course, I'm assuming this was done in Photomatix. 1Ds Mk II, 1D Mk II, 50D, 40D, XT (for my son), 17-40L, 24-105L, Bigma 50-500 EX DG, Sigma 150 Macro EX DG, Tokina 12-24 AT-X, Nifty Fifty, Tamron 28-300 (for my son), 580ex II, 430ex II
TGrundvig Goldmember 2,876 posts Likes: 3 Joined Oct 2009 Location: Colorado More info | Jul 25, 2010 15:18 | #5 One more thing, you might want to boost the highlight saturation a bit. The sky looks really uneven. You might not have captured enough DR for the sky to come out right. The strength slider might be able to even it out a little. 1Ds Mk II, 1D Mk II, 50D, 40D, XT (for my son), 17-40L, 24-105L, Bigma 50-500 EX DG, Sigma 150 Macro EX DG, Tokina 12-24 AT-X, Nifty Fifty, Tamron 28-300 (for my son), 580ex II, 430ex II
Jul 26, 2010 09:35 | #6 Thank you, guys. Appreciate all the comments.
mknabster Senior Member 827 posts Joined Jul 2005 Location: Limerick, PA, USA More info | Jul 26, 2010 09:46 | #7 I have never been able to grasp HDR myself, but the 2nd attemp looks a lot like a painting to me. - Matt
TGrundvig Goldmember 2,876 posts Likes: 3 Joined Oct 2009 Location: Colorado More info | Jul 26, 2010 17:42 | #8 Aleness wrote in post #10604804 Thank you, guys. Appreciate all the comments. Actually, I think I didn't grab enough range, since it was only -1, 0, +1. I have one more question. When I push saturation, I get this white outline around the roof and I can't get rid of it. Any suggestions? I'm not sure what's causing it.
That white line is called a halo. You can remove it by adjusting the strength and/or light mode. 1Ds Mk II, 1D Mk II, 50D, 40D, XT (for my son), 17-40L, 24-105L, Bigma 50-500 EX DG, Sigma 150 Macro EX DG, Tokina 12-24 AT-X, Nifty Fifty, Tamron 28-300 (for my son), 580ex II, 430ex II
Jul 28, 2010 17:10 | #9 Do you capture only 3 images or you go for 5? From what I read, 5 images usually is a good number. The only problem that 7D doesn't allow more than 3 images AEB. Bunnies will rule the world!
TGrundvig Goldmember 2,876 posts Likes: 3 Joined Oct 2009 Location: Colorado More info | Jul 28, 2010 18:04 | #10 Aleness wrote in post #10620672 Do you capture only 3 images or you go for 5? From what I read, 5 images usually is a good number. The only problem that 7D doesn't allow more than 3 images AEB. ![]() I've seen a couple of techniques described here, such as setting different exposures to C1 and C3, but that would probably move the camera, creating unwanted ghosts. I have played around with 3, 5, 7 and even more. Basically, it all depends on the dynamic range. There usually is not set number for me. If the dynamic range is really wide (like the inside of a house on a really bright day) I may capture -4, -3, -2, -1, 0, +1, +2, +3, +4. From that I will probably delete one or two but I would rather have more than I need. 1Ds Mk II, 1D Mk II, 50D, 40D, XT (for my son), 17-40L, 24-105L, Bigma 50-500 EX DG, Sigma 150 Macro EX DG, Tokina 12-24 AT-X, Nifty Fifty, Tamron 28-300 (for my son), 580ex II, 430ex II
| Latest registered member is semonsters 1465 guests, 133 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
