Thread started 24 Jul 2010 (Saturday) 19:55
Secret to bright white backgrounds in photos.
Soliz387
Jul 24, 2010 19:55 |  #1
Probably an old question that's been asked many times but I need help. I've been doing some studio shoots lately with white seamless paper background. Been trying different lighting techniques but background comes out looking grayish. Can someone provide some insight on how to get that nice crisp, bright white background? thanks ahead of time for your help.
I've shot with 2 lights and 3 with one facing background. but still looking dingy gray.
Rene
Canon 50D, Sigma 70-200 2.8, Sigma 150 Macro
Canon 85 1.8, Canon 50 1.8, Tamron 28-75 2.8
430ex, Kenko Tubes
photoPanda
Jul 24, 2010 20:02 |  #2
Try having two lights facing the background, one on either side facing inwards. That should even out the lighting for a start.
If it's still grey you need to up the power or change your ISO/aperture to let more light in. What light sources are you using?
gonzogolf
dumb remark memorialized
Gallery: 559 photos
Jul 24, 2010 20:08 |  #3
Like photopanda said you need at least 2 lights on the drop to make it even. Those lights need to be about a stop or two brighter than the light falling on the subject in order to make them white,
JeffreyG
Gallery: 42 photos
Jul 24, 2010 20:23 |  #4
Soliz387 wrote in post #10597018 (external link)
Rene
Did you set the one light facing the background to fire at full power (1:1) in manual flash mode? If it is in E-TTL mode it will fire at very low power.
Wilt
Jul 24, 2010 21:37 |  #5
You MUST independently light the b/g in order to make it white. The Inverse Square Law prevents lighting backgrounds with the same lighting unit as the subject, while having the b/g come out truly white.
yogestee
Jul 24, 2010 21:56 as a reply to  @ Wilt's post |  #6
What Wilt mentioned holds true,, you must light your white background to get it absolutely white to a point the white background burns out..
I use two 430EX off camera for main lighting and fill.. Mostly only one 430EX for main and reflector for fill.. I have an old Nikon SB-28 which I use to light my white background.. All flashes are set to manual exposure..
I place the SB-28 behind the subject aimed at the background, about one meter from the background..I take a flash meter reading from the main source and a reading off the background flash.. If for example my main flash reads f/8 I adjust my background flash from anything to f/4 to f/8.. You have to be careful not to set your background flash too high as you can get spill, even flair.. It doesn't take much for the background to go pure white.. I also use the little wide angle diffuser to spread a more even light..
Here is an example..
Jurgen
yogestee
Jul 24, 2010 22:01 |  #7
photoPanda wrote in post #10597057 (external link)
This will also change the exposure for the subject and not only the background light..
Both the main flash and background flash have to be adjusted independently to get the best results..
Jurgen
Markk9
Jul 25, 2010 09:00 |  #8
The easiest way to shoot and remember how to get a white back ground is to shoot the back lights at 2 stops more power than you main light on the subject.
Mark
Retired Eagle Driver.............Lon​g Live the Eagle.
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jul 25, 2010 09:33 |  #9
Same white background - different looks (external link)
More of his white seamless tutorials (external link)
White Seamless Tutorial :: Part 1 :: Gear & Space (external link)
Wilt
Jul 25, 2010 14:22 |  #10
Markk9 wrote in post #10599358 (external link)
Mark
I think the above statement needs modification and clarification...
If you are using REFLECTED light readings off the background, the readings taken should be +2EV higher (actually more, at +2 to +3EV, for pure white background) than reflected light readings taken of an 18% gray card at subject position.
If you are using INCIDENT light readings, the reading at the background should be at least the same brightness (if not +1EV) as the incident light reading taken at subject position.
Too much light has the problem of bleed over bounced flare around the subject, so you have to be careful to not cause this problem.
Markk9
Jul 25, 2010 14:44 |  #11
Wilt wrote in post #10600624 (external link)
For my set ups, using a hand held light meter, I set the subject at f5.6 or F8 depending on what I need. The light reflecting off the background using a using a light meter is set f11 for the 5.6 and f16 for the 8. I was taught this a long time ago and has always worked for me.
Yes, to much light will cause problems, just as to little will.
Mark
Wilt
Jul 25, 2010 15:47 |  #12
Markk9 wrote in post #10600720 (external link)
Mark
Not to be argumentative, but to be illustrative and educational to others...
If a white background is +2EV above 18% gray card (I just measured a MacBeth card with spot meter and the difference was +1.0EV), lighting the background at the same level as the gray card at the subject puts the white background at +2EV to begin with. So making the background lighting be +2EV brighter puts the white background at +4EV (as measured by reflected light). In practice, using 0EV for background light is not sufficient for pure white...it will be about 92% white. At +1EV it will be about 99% white, and at +2EV it will be at 100% (it actually will hit 100% white at about +1.5EV brighter than subject's incident light). 'Bright white' backgrounds can be a bit brighter (compared to the white patch on the MacBeth card)
I was not disputing what Mark posted earlier, but wanted merely for people to understand the situation in a more unambigous manner, since not everyone uses an incident meter.
Soliz387
Jul 26, 2010 19:12 |  #13
Beautiful. Thanks to everyone. I knew this was the right forum to ask. Thanks for the great help guys.
430ex, Kenko Tubes
Soliz387
Jul 26, 2010 19:12 |  #14
gonzogolf wrote in post #10597078 (external link)
This was basically what i did and it worked beautifully. thanks guys.
430ex, Kenko Tubes
Soliz387
Jul 26, 2010 19:14 |  #15
yogestee wrote in post #10597588 (external link)
Thanks for the great info. What diffuser do you use if you dont mind me asking?
430ex, Kenko Tubes
8,563 views & 0 likes for this thread, 8 members have posted to it and it is followed by 2 members.
1065 guests, 128 members online
