Thread started 25 Jul 2010 (Sunday) 11:01
Circ Polarizer - Broken
kram
obvious its pointless
Jul 25, 2010 11:01 |  #1
Have a Hoya 77mm CP - and yesterday, it has come off as 2 seperate pieces. One that is without the glass and has the groove that attaches to the lens and the other that has the glass!!
There is also a thin strip of metal that looks like a lining that seems to be removable - this was inside the groove of the first ring, and potentially something that should help hold these two pieces together....
Is this something that can be fixed or is it time for another CP??
Canon 7D , Canon 6D, 100-400 L, 24-105 F4 L, 50 F1.4, Tokina 12-24 F4, Kenko Teleplus Pro DG 1.4X Extender
My Gallery (external link)
kram
Jul 25, 2010 11:18 |  #2
Forgot to add that the groove is not a full ring but a wire that has two ends!!
Jonta
Jul 25, 2010 11:49 |  #3
Within warranty? If not, then insurance (not likely) or new one.
argyle
Jul 25, 2010 12:22 as a reply to  @ Jonta's post |  #4
There are quite a few threads in here discussing this very problem, yet folks still go with Hoya polarizers. :shock: The cost advantage of saving a few dollars over that of buying a B+W up front is pretty much negated when you need to buy a replacement polarizer.
If its out of warranty, you're probably stuck with it. FWIW, certain Hoya polarizers are prone to coming apart unexpectedly...I'd recommend that you buy a B+W Kaesemann MRC polarizer. A little more expensive, but you won't have this problem.
SkipD
Joined Dec 2002
Jul 25, 2010 12:38 |  #5
Chances are the filter is not truly broken but merely disassembled. I am fairly certain that I could reassemble it, but not knowing precisely what it looks like I cannot tell you how here.
Skip Douglas
1,350 views & 0 likes for this thread, 4 members have posted to it.
496 guests, 157 members online
