Thread started 27 Jul 2010 (Tuesday) 00:47
Camera body & sharpness
ctrlcctrlv
Joined Sep 2009
Jul 27, 2010 00:47 |  #1
I was just wondering if there was a way to tell if a camera body has a sharpness issue. I remember reading articles about how sometimes people would notice all of their lenses needed similar micro-adjustments due to the camera being at fault. I own an XSi so it is impossible for me to determine via MA.
Photography is like women, they're both expensive to support and you'll never completely understand them.
Canon 40D | 24L II | 50mm 1.4 | 100mm 2.8 Macro
SiaoP
Jul 27, 2010 00:50 |  #2
If you don't notice I don't think it should matter but a trick you can do is get a ruler and place it against a wall at 45 degrees. Then mount your camera on a tripod level to the ground and autofocus on the 6" mark or something in the middle. Then pull the image on a computer and see if more ticks are visible behind or in front of the focus point. Typically a lens should back focus slightly more than front.
My Flickr (external link) | Gear List
yogestee
Jul 27, 2010 20:28 |  #3
ctrlcctrlv wrote in post #10609333 (external link)
It is normally not a fault of the camera.. It is usually the combination of both camera and lens..
Lenses that are sharp on my 20D were so-so on my 50D until I did a little AF Micro adjustment..
It all to easy to blame the equipment than address technique or getting to know your equipment..
Jurgen
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Jul 27, 2010 22:04 |  #4
SiaoP wrote in post #10609341 (external link)
Could use my DIY setup too, it works on the same premise.
https://photography-on-the.net …light=diy+micro​adjustment
Amamba
Jul 28, 2010 11:05 |  #5
Yes it does happen. You need to test it with more than one lens at same settings to see if it's a body issue. I had soft photos when I first got my XTi and everybody kept telling me it was a user error. I did the focus chart test but it was fairly inconclusive. I only had one lens back then, it was old and beat up and I thought it was the lens problem. When I bought a brand new Nifty and saw the same problem, I sent the body to Canon, it came back with a letter stating they found and fixed a focusing issue. Focused perfectly ever since, until I sold it 2+ years later.
Ex-Canon shooter. Now Sony Nex.
Life Lessons: KISS. RTFM. Don't sweat the small stuff.
My Gear List (external link)
1,390 views & 0 likes for this thread, 5 members have posted to it.
836 guests, 108 members online
