Thread started 27 Jul 2010 (Tuesday) 16:08
Robust Mini Tripod
ampleforth
Joined Jun 2010
Jul 27, 2010 16:08 |  #1
Hi all,
i am looking for a very solid mini tripod made of metal (no plastic) with a very secure ball head that has no plastic components and that holds a Canon Rebel with glass securely.
What do you use? What do you suggest?
Ampleforth
Jonta
Jul 27, 2010 16:10 |  #2
Define "mini". Tabletop? Travel? Weightrequirements? (Glass weighs a lot. Or not. Or a bit).
Bearmann
Location: I live behind Graceland in a tool shed. I often meet the man early in the morning at Krispy Kreme.
Jul 27, 2010 16:24 |  #3
For what purpose? Would a Bogen superclamp with your choice of ballhead fill the bill?
Barry
http://b-r-s-photo.zenfolio.com (external link) (remove the dashes)
lannes
Jul 27, 2010 20:05 as a reply to  @ Bearmann's post |  #4
I'd also have a look at the Slik Sprint Mini II
http://www.thkphoto.co​m …slik-sprint-mini-2-a.html (external link)
The small ball head that comes with it holds the 5dm2+Bg-E6+24-105mm
IMAGE: http://i81.photobucket.com/albums/j226/lannes2007/IMG_8060-1.jpg
IMAGE: http://i81.photobucket.com/albums/j226/lannes2007/IMG_8061-1.jpg
It doesn't extend very high because of it's compactness and 13.8in length when folded.
pixel_junkie
Jul 27, 2010 20:21 |  #5
lannes wrote in post #10614720 (external link)
This actually looks like a good travel tripod. I'm on the market for one and this may be it. I have a quick question for - do you know if it is possible to remove the head that comes with it? I would want to mount my own head so I can use my L plate.
Website (external link) | Blog (external link)
pixel_junkie
Jul 27, 2010 20:35 as a reply to  @ pixel_junkie's post |  #6
Heh, check out this thing:
http://www.amazon.com …ics&qid=1280280​894&sr=8-1 (external link)
It actually has good reviews
2mnycars
Jul 27, 2010 20:37 |  #7
Leica mini tripod and Leica ball head. I've had mine for 35 years or more. Available on ebay...
Tripod is about 10 inches high... ball head...there are 2 sizes. Mini is about 2 inches high; large ball head is about 3-1/2 inches high.
Makes a good chest - pod with a dslr. 3 legs spread out on your torso, ball head set so you can look through the viewfinder.
Only concern? Folded up it looks like a pistol and silencer in an x-ray at an airport. Not good for carry on.
edit: link:
http://cgi.ebay.ca …ain_0&hash=item​563ab84fc0 (external link)
That's a very high price!!
Dave
lannes
Jul 27, 2010 21:19 |  #8
pixel_junkie wrote in post #10614787 (external link)
You can just unscrew the SBH-100DQ ball head, but the screw mount is only a 1/4-20in thread, so you need to watch out for this or get an adaptor to go up to the 3/8in commonly used.
lannes
Jul 27, 2010 21:20 |  #9
pixel_junkie wrote in post #10614875 (external link)
If your going that small, I'd have to recommend a Joby Gorrillapod SLR Zoom and the matching ball head, but it's mostly plastic.
pixel_junkie
Jul 27, 2010 21:27 as a reply to  @ lannes's post |  #10
Thanks Lannes! That Slik may work. The Gorrillapod has very poor reviews.
sportesan
Joined Sep 2009
Jul 27, 2010 21:41 |  #11
I have a Gorillapod which works well in certain circumstances where a flat surface isn't available.
The SLR zoom should be able to support the weight, it's the model I have.
http://sportesan.smugm​ug.com (external link)
Rebel XSi, Tokina 11-16, Canon 18-55 IS, Canon 55-250 IS, Canon 50 1.8
lannes
Jul 27, 2010 22:49 |  #12
pixel_junkie wrote in post #10615192 (external link)
It works with heavier kit, if you keep the legs at right angles, even with my gorrillapod legs which are the 20bucks clone variety. The joby ballhead is the real deal though.
IMAGE: http://i81.photobucket.com/albums/j226/lannes2007/IMG_8842.jpg
ampleforth
Joined Jun 2010
Jul 28, 2010 17:21 |  #13
Jonta wrote in post #10613444 (external link)
Here a list of requirements. Sorry for starting so imprecise.
1) 'Mini' here means I want 10-15 cm ( = up to 5 inch) long legs
2) No quick release
3) No extra handle on the head or anything to quick adjust or release; I like it simple but sturdy
4) Metal construction (can be aluminum) but no plastic - at least not in any of the critical parts (especially ball head)
5) ball head should be high quality and made of one piece
6) made to hold a Rebel with a Tokina 12-24 tank => 4 pounds (?)
I bought a number of these mini's and they usually worry me. They have plastic components and I would only trust them with a web cam or a P&S. I don't mind paying 50$ for this but it should be something that lasts and can securely hold a cam in normal horizontal position (no fancy positions are required).
Ampleforth
RayHff
Jul 28, 2010 18:36 |  #14
This is what I use.
http://www.promaster.c​om …products.asp?pr​oduct=7812 (external link)
You can use it as a tripod or clamp it to almost anything. It's incredibly versatile.
Although not my thread, check this one to see it in use:
http://digital-photography-school.com …etop-window-anywhere.html (external link)
DisrupTer911
Jul 29, 2010 10:38 |  #15
I've used this regularly with my 1Ds2 and 70-200/2.8 IS. holds just fine.
http://www.bhphotovide​o.com …Digi_Tabletop_T​ripod.html (external link)
www.vividemotionphotograph​y.comexternal link
6,806 views & 0 likes for this thread, 12 members have posted to it.
Robust Mini Tripod
2815 guests, 166 members online
