Thread started 28 Jul 2010 (Wednesday) 02:04
Laptop for 5D mark 2 RAW files
dip
Jul 28, 2010 02:04 |  #1
im going to college this fall and will be taking my 5D mark 2 with me. im only going to have a laptop as my only computer and i want it to be able to handle the 5D2 RAW files nicely. any suggestions on a laptop that will be able to do this. other features i want are decent battery life (4-6 hours). thanks guys!
Canon 6D | 24mm f/2.8 IS | 35mm f/2 IS
[YOUTUBE CHANNEL (external link)]
DetlevCM
Jul 28, 2010 07:10 |  #2
dip wrote in post #10616529 (external link)
Unless you use an extended batter NO laptop will allow you to do heavy work for 4-6 hours.
You need something greater than a 2GHz Core2Duo - that will suffice for the 5D MK II, I'm on a 2,5GHz Core2Duo.
Ideally you'd go for an i5 or i7 though => newer architecture.
If you can afford it, the Vaio Z is a great little choice - it has a pretty good screen too.
Ideally ask here for notebook question:
http://forum.notebookr​eview.com/ (external link)
Using the FAQ: http://forum.notebookr​eview.com …-read-before-posting.html (external link)
5D MK II AF Satisfaction Poll | Reduced Kit List
A Basic Guide to Photographyexternal link | Websiteexternal link
Flickrexternal link | Artflakesexternal link | Blurbexternal link
dip
Jul 28, 2010 09:22 |  #3
alright thanks. i didnt really mean 4-6 hours of image processing. i meant 4-6 hours in general. any more suggestions?
DetlevCM
Jul 28, 2010 09:30 |  #4
dip wrote in post #10617950 (external link)
Z with an extended battery should do that - not sure about the normal one.
On the older SZ (which I have) I originally got 4,5hours out of 80%...
But on the small expensive side the Z is the only one that springs to mind - it has a pretty good screen too.
monk3y
Totally Saturated
Jul 28, 2010 09:40 |  #5
how much is your budget? alienware? haha M15x...
iSax1234
Jul 28, 2010 10:51 |  #6
15in MacBook Pro! It will powerhouse through you're images, amazing high res screen and 8 hours of battery life. Well honestly you can get like 5-7.5 really using it.
5d gripped - 85mm f/1.8 - Tamron 28-75 f/2.8 - 430EX - Yongnuo 560
Flickr (external link) - My Site (external link)
Andrew
Tony-S
Jul 28, 2010 11:58 |  #7
Any of the MacBook Pros will serve your needs.
DetlevCM wrote in post #10617322 (external link)
Sure you can. A MacBook Pro will go that long with a little to spare.
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
DetlevCM
Jul 29, 2010 03:47 |  #8
Tony-S wrote in post #10618956 (external link)
You won't get the advertised battery life out of any laptop - doesn't matter what name it has or whether it has an apple on it that's starting to rot.
Light usage - yes, Vaio Z - or the G series originally got even up to 10 hours - my SZ got 4-4,5 hours from an 80% charge when I still had my HDD (SSD needs less energy).
But NO laptop will get much more when used heavily as in Photo editing.
And my light use was generally web browsing - reading the news, some Excel, VBA script in Excel and word.
Tony-S
Jul 30, 2010 11:38 |  #9
DetlevCM wrote in post #10623372 (external link)
Sure you can from a MacBook Pro. It's been verified by many people, including AnandTech (external link). Apple advertises 8 hours and that's what you get, even a little more.
Photo editing isn't that taxing on batteries. You want to use a battery in a hurry, run any Flash animation. Flash junk is electric drain.
Moppie
Moderator
Gallery: 22 photos
Joined Sep 2004
Jul 30, 2010 18:47 |  #10
Tony-S wrote in post #10631712 (external link)
Ah the magic energy sucking properties of flash :rolleyes::rolleyes:
Battery consumption is dependent on power requirements of the hardware which is dependent on the processing requirements of the software.
Running a complex flash game on my PC cranks the CPU usage up to around 15%.
Editing photos easily takes it to 100%.
Guess which one is going to require the most power?
Have you Calibrated your Monkey lately?
Now more than ever we need to be a community, working together and for each other, as photographers, as lovers of photography and as members of POTN.
MaxxuM
Jul 30, 2010 21:09 |  #11
I get about 5-7 hrs of life out of my i7 MBP on average. Editing photos maybe 3.5 hrs unless I turn the brightness down. The problem is the video switching - it really sucks down the battery. Little flash games are not my problem. It's the movies that push the CPU up into the 40-60's most of the time.
There are not many PCs that get past 3 hrs and those that do are typically expensive or have extra large batteries that stick out in some way.
Vendetta0814
Jul 31, 2010 01:33 |  #12
i just bough a 15in i5 MBP and it handles my 5DMKII photos perfectly and fast!!
it was expensive though
DetlevCM
Jul 31, 2010 03:02 |  #13
Moppie wrote in post #10633880 (external link)
So true :)
I really wonder how someone can claim running a CPU at 100% (at least to "decode" the RAW) isn't taxing the computer.
If ruinning the CPU at 100% isn't what is?
dip
Jul 31, 2010 04:08 |  #14
my budget will be around 2000. i'd really like a mac because we have 4 of them at home right now, but some of the programs that i will be running for school will be windows only. i dont want have to bootcamp or run a VM all the time. i dont think its worth it.
thanks for all of the suggestions guys! i might go for a vaio F (the 16 inch one) with i7 quad, 8 gigs of ram and an ssd or an hp envy with the same config. still considering the MBPro, but i doubt that im going to get one. thanks!
DetlevCM
Jul 31, 2010 04:10 |  #15
dip wrote in post #10635926 (external link)
The Vaios have become very nicely priced recently - at 2000$ also have a look at the Z - just a dual core i7, but at 13,1" and 1,43kg might be worth it :)
3,771 views & 0 likes for this thread, 9 members have posted to it.
1041 guests, 170 members online
