dennisatmph wrote in post #10620962
I am really so sorry
Windows7
I just transfered all my desktop picutre folder into the ext HDD
I tagged it with windows 7 tagging function ( all the JPEGs)
There is a small box to tell me searches can be slow in non indexed locations ( ie the ext HDD)
The options are
1. add to index
2. modify index locations
Do you think may be i should index this ext HDD, then may be i can perform tag searches?
I just did a quick test and it would appear the tags are stored in the files, but you should check them just to be sure.
One option is this:
In a Windows Explorer window, click on "organize" and then "folder and search options." Then in the "search" tab you can tell the computer to "always search file names and contents." Good for the short term if you want, but all searches (everywhere) will take longer).
What you should do is simply index the drive. In the search box (start menu) search "index" and then click on "Indexing Options." Click "Modify" and then choose the external hard drive, check the box next to it, and click "Okay."
Let it sit for a while to index the drive and then searching should work.
