Thread started 29 Jul 2010 (Thursday) 18:47
White Balance
slkfis
Jul 29, 2010 18:47 |  #1
I just read about WB lens caps on the net. Sounds fishy to me. Has anyone any experience with these they would be willing to share.
thxsx
slkfis
Canon 40D
28-135 KIt --- 70-200mm IS 2.8
As I learn to add, I will!
lannes
Jul 29, 2010 21:39 |  #2
It's just another way of setting the white balance, it's easy to use just take a shot with the cap on and then use this image as the reference to set the "custom" white balance. I find it more accurate than Auto WB, but I don't use it all the time, just mainly at night. If you shoot raw, you can adjust the white balance in post processing in programs like DPP.
http://www.balens.ca/ (external link)
tonylong
...winded
Gallery: 60 photos
Jul 29, 2010 22:13 |  #3
There is an alternative that defines the word "cheap" -- a white coffee filter over your lens has a good rep for setting a CWB (or using as a target in a Raw converter).
Tony
slkfis
Jul 30, 2010 08:42 |  #4
Hey Guys,
I appreciate the replies I'll try the coffee filter trick, I can afford that.
thxs
slkfis
bob
Canon 40D
pknight
Gallery: 37 photos
Joined Feb 2006
Jul 30, 2010 10:16 |  #5
tonylong wrote in post #10628603 (external link)
Or cut a white foam cup to fit over your lens to get yiour WB shot. (This setup can also be used to turn your camera into an incident light meter, but that is another thread...)
Digital EOS 7D Mark II Canon: EF 50mm f/1.8 II, EF 50mm f/2.5 Compact Macro, Life-Size Converter EF Tamron: SP 17-50mm f/2.8 DiII, 18-400mm f/3.5-6.3 DiII VC HLD, SP 150-600 f/5-6.3 Di VC USD G2, SP 70-200 f/2.8 Di VC USD, 10-24mm f/3.5-4.5 DiII VC HLD Sigma: 30mm f/1.4 DC Art Rokinon: 8mm f/3.5 AS IF UMC
Jim_T
Joined Nov 2003
Jul 30, 2010 18:37 |  #6
I use a translucent white Burger King drink cup lid. :)
The resulting image can be used for 'custom white balance'... This works out great even when you shoot RAW because the acquired white balance is applied to all the RAW files by default. You don't have to do any more white balance work when post processing your RAW files.
992 views & 0 likes for this thread
White Balance
Latest registered member is ViciousKing
942 guests, 289 members online
