Thread started 30 Jul 2010 (Friday) 14:00
EOS 7D Error 30
Foil
Jul 30, 2010 14:00 |  #1
Hi, i was at the racetrack today when after around 2hours my Cam went Awire,it came up with the "Error 30" in the Display and i saw the Blinking Battery Symbol which ended up in sending the Cam in for Repairs last time and i thought Please not again,not now!
For some time i made a clown of myself Removing batteries and checking my Lens and TC for Dirt on the Contacts,putting everything back together taking 3 shot and Staring allover again,i googled the Error and it said i might have a Shutter Problem,anybody else had this Issue? thanks for any Advice
Pics from an Selfmade Clown with a Shutter Problem :)https://photography-on-the.net …showthread.php?​p=10632468
Still learning Day by Day.Canon1D IV,7D Gripped,40D Gripped,350D,PENTACON SIX & CZJ Biometar 80 2.8 ,10-22mm,24-70 2.8, 85 1.8,50 1.4,50 1.8,100 2.8, 70-200 2.8,100-400mm, 300 2.8
msowsun
"approx 8mm"
Gallery: 18 photos
Mar 10, 2012 00:24 |  #2
My 7D has about 60,000 clicks and just started giving me Error 30 if I use Liveview a lot. Apparently Liveview opens the shutter more than is usual and it can cause the shutter to stick.
I read on various forums that the way to fix this is to smack your camera around a little because Error 30 usually means a stuck shutter curtain. They also suggest firing off a few high speed bursts at 8fps to lubricate and free up the shutter blades.
I did all those things and IT WORKS! ( I have posted this in three old threads so it will turn up if someone is searching out error 30)
2,745 views & 0 likes for this thread, 2 members have posted to it.
EOS 7D Error 30
1193 guests, 166 members online
