Thread started 30 Jul 2010 (Friday) 22:47
Filter Question for tomorrow
mtnbkr1
Joined Jun 2010
Jul 30, 2010 22:47 |  #1
Tomorrow I will be shooting a motercycle event in nasty sun, and picked up a CPL for this purpose. Does anyone know if CPL's have built in UV filtering? Or should I use both the UV and CPL filter. Thanks
5Dc | 85L | 1200 f5.6L | Lighting
mike_d
Jul 30, 2010 23:10 |  #2
UV filtering isn't needed or beneficial on DSLRs and stacking filters isn't advised.
topper66
Jul 30, 2010 23:12 as a reply to  @ mike_d's post |  #3
I would recommend a neutral density filter (not a graduated one).
http://www.flickr.com/​photos/topper1/ (external link)
7D & a few lenses with red stripes.
Mike ­ R
Jul 30, 2010 23:51 |  #4
Be careful with the CPL filter. While they are great, they do have limitations and if you could end up making the sky an unnatural dark blue or with very dark corners. Just pay close attention. Have fun
Mike R
www.mikerubinphoto.com (external link)
mtnbkr1
Joined Jun 2010
Jul 31, 2010 00:04 |  #5
Thanks guys, I guess I will experiment with all combinations since I have the time. Also, does using such a filter reduce the light coming in by a few stops?
mike_d
Jul 31, 2010 00:06 |  #6
mtnbkr1 wrote in post #10635152 (external link)
A CPL reduces your light by 1-2 stops depending on brand, angle to the sun, and how its adjusted. So don't use it unless you need it.
SkipD
Joined Dec 2002
Jul 31, 2010 05:50 |  #7
mtnbkr1 wrote in post #10634793 (external link)
What is your anticipated problem shooting in bright sun?
What do you expect a filter to accomplish for you? I suspect you may have some unrealistic expectations.
Do you know what a polarizing filter does?
Do you have a lens hood for each of your lenses? If not, that would be a superb accessory to have and use, as they can improve your images by blocking stray light sources that can cause flare and other image degradation.
Skip Douglas
mtnbkr1
Joined Jun 2010
Jul 31, 2010 18:48 |  #8
The problem is that the sun is somewhat behind the riders, so the filter would reduce its glare. Yes i have a lens hood but my understanding is that a filter would linearize the stray light from the sun, and reduce glare coming from the bike's shiny parts
SkipD
Joined Dec 2002
Jul 31, 2010 21:26 |  #9
mtnbkr1 wrote in post #10638862 (external link)
I seriously doubt that a polarizing filter would do much for the sun's glare if the sun is actually in the picture or even close to being so.
Also, to reduce the reflections on the bikes, you'd have to adjust the filter's rotation for each angle to the sun that you were photographing.
Skip Douglas
832 views & 0 likes for this thread, 5 members have posted to it.
2720 guests, 157 members online
