hi everyone ....
i plan to buy one of those lenses , which one is better beetwen those lenses ?
anyone can give any suggestion ?
any comment would be appreciated ....
antique Member 90 posts Joined Jul 2010 More info | Jul 31, 2010 00:11 | #1 hi everyone .... Canon EOS 1000D KIT | UV Filter HOYA
dslrphoto Member 86 posts Joined Aug 2009 Location: Hoston TX More info | Jul 31, 2010 00:17 | #2 I would go with 55-250. It is sharp, colors are good and it is lite. Image stabilization works well. I have some very good shots with it (check birds folder on the link below). I think it is best value for the price. Gear: Canon XSi, Canon EF-S 17-55 f2.8 IS USM, Canon 85 f1.8 USM, Canon EF-S 55-250 f4-5.6, Canon 70-200 f4L IS USM
Jul 31, 2010 00:23 | #3 dslrphoto wrote in post #10635220 I would go with 55-250. It is sharp, colors are good and it is lite. Image stabilization works well. I have some very good shots with it (check birds folder on the link below). I think it is best value for the price. thanks for your quick reply , yes i think so .... but don't you think tamron has a great body , i mean looks strong .... Canon EOS 1000D KIT | UV Filter HOYA
JackProton Goldmember 2,348 posts Joined Feb 2007 More info | The Tamron's an OK budget telephoto. The build is fairly good but it does extend out quite a bit at 300mm which makes it somewhat less robust than it might first appear (not to mention much easier to accidentally smack the end of the lens into something or someone). IS image stabilization can also be extremely useful on a telephoto, particularly a slower one - unless you plan on using a tripod or monopod - so I would tend to give IS more weight in the decision than the Tamron's apparent build. I don't think you can find better than the 55-250mm IS in this price class.
TheRan Goldmember 1,555 posts Likes: 2 Joined Jan 2010 Location: Hertford, England More info | Jul 31, 2010 17:47 | #6 Tamron:
svg223 Hatchling 3 posts Joined Dec 2008 More info | Aug 03, 2010 14:29 | #7 I have both. 40D, 18-55IS, 15-85IS, 70-200L 2.8, 55-250IS, SMC Takumar 55 1.8, Tamron 500mm cat
| Latest registered member is semonsters 874 guests, 128 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
