phreeky wrote in post #10639870
What do you mean only choices? You already own them?
Having not shot hummingbirds I wonder whether fast AF is really needed. Based on the shots I see they appear to be hovering and if the lens is pre-focused most should be fast enough, and MF may even be more suitable in some cases.
A 135mm might be a suitable lens, or if you're considering the 180m macro then why not the Canon 200mm F/2.8? A prime will generally result in nicer bokeh where close by branches and so on are only slightly out of focus, but if that's not a real issue then maybe you should just try your 70-200 a bit more.
Wow, Phreeky. Yes, moderately fast AF is a requirement, to be sure, and the camera's AF needs to be pretty good too. They appear to be hovering only because of fast AF and excellent technique. These birds do not stay in one place for very long
. I do agree that if you don't have a 7d or 1 series body, pre-focus and MF is usually the way to go.
Good lenses for hummingbirds (imo) are the Sigma 180 and the Canon 300 f/4 IS. 135L and 200/2.8 L don't have a high enough magnification factor for these tiny birds. With rare exception, a prime is going to be killer for feather detail, a zoom, well, not so much, lol.
One from this season:
| HTTP response: NOT FOUND | MIME changed to 'image/gif' |
