I am looking at doing some internal shots of a NeoNatal ITU I designed but I am unsure what would be the best lighting setup (budget of say £200-£300)
Any advice would be much appreciated
Andy
slartibardfast Goldmember 1,000 posts Likes: 10 Joined Jul 2007 Location: Shropshire England More info | Aug 01, 2010 06:31 | #1 I am looking at doing some internal shots of a NeoNatal ITU I designed but I am unsure what would be the best lighting setup (budget of say £200-£300) www.three6t.co.uk
slartibardfast THREAD STARTER Goldmember 1,000 posts Likes: 10 Joined Jul 2007 Location: Shropshire England More info | Aug 01, 2010 06:55 | #2 been having a look on Ebay and wondered if this sort of setup would be ok to use www.three6t.co.uk
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Aug 01, 2010 07:16 | #3 The required lighting depends on what sort of shots you intend to make and what sort of lighting there is in the area already. Skip Douglas
slartibardfast THREAD STARTER Goldmember 1,000 posts Likes: 10 Joined Jul 2007 Location: Shropshire England More info | Aug 02, 2010 18:02 | #4 SkipD, www.three6t.co.uk
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Aug 02, 2010 19:24 | #5 You could use flash to add light, but then you'd need to gel it to mach white balance. "I think the idea of art kills creativity" - Douglas Adams
egordon99 Cream of the Crop 10,247 posts Likes: 3 Joined Feb 2008 Location: Philly 'burbs More info | Aug 02, 2010 19:45 | #6 slartibardfast wrote in post #10649625 SkipD, Thanks for that. so if I understand correctly if the flourescants are on then i should only suppliment them with additional flourescent lights? so from that i assume that strobe lighting is not suitable? also that the speed needs to match those you have identified or slower. I am going to be using a tripod ![]() thanks for you help Andy You could set it up so the flashes/strobes are providing ALL the illumination. Then it doesn't matter what temperature the ambient lights are.
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Aug 02, 2010 20:26 | #7 slartibardfast wrote in post #10649625 SkipD, Thanks for that. so if I understand correctly if the flourescants are on then i should only suppliment them with additional flourescent lights? so from that i assume that strobe lighting is not suitable? also that the speed needs to match those you have identified or slower. I am going to be using a tripod ![]() Andy, the point is that you don't want to be mixing light type sources (daylight or flash, tungsten, fluorescent, and a few others) in the same scene. Unless you can afford to light the whole scene with flash - overpowering the ambient fluorescent lighting - then you should probably try to do the job with the ambient lighting (possibly supplemented with a bit more of the same type of lighting). A sturdy tripod would be ideal for a project like this. egordon99 wrote in post #10650138 You could set it up so the flashes/strobes are providing ALL the illumination. Then it doesn't matter what temperature the ambient lights are. Unfortunately, his stated budget probably won't allow for enough flash lighting to do the whole job. Skip Douglas
slartibardfast THREAD STARTER Goldmember 1,000 posts Likes: 10 Joined Jul 2007 Location: Shropshire England More info | Aug 03, 2010 17:04 | #8 OK thanks for your help on this www.three6t.co.uk
| Latest registered member is semonsters 903 guests, 122 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
