Thread started 03 Aug 2010 (Tuesday) 01:30
Tripod Decision
Poe
Aug 03, 2010 01:30 |  #1
So I think I've decided to get a CF tripod. I'm debating between the Manfrotto 055CXPRO3 or a Gitzo probably a 25XX or 35XX. Should I just go for the Gitzo or does the Manfrotto have a similar lifespan as the Gitzo?
Or are there other CF tripds I should look into?
The tripod needs to support a ball head (e.g. RRS), possible macro rails in the future, the camera, L bracket, and lens, perhaps up to a 200 2L (thinking of the future :P).
I'm trying to "buy right, buy once", rather than periodic upgrading.
Feedback appreciated. Thanks!
Nikon D750, D7200 | Nikon-Nikkor 14-24G, 60G Micro, 70-300E | SIGMA 35A, 105 OS, 24-105 OS | ZEISS Distagon 2.0/25 Classic, Apo-Distagon 1.4/55 Otus, Apo-Planar 1.4/85 Otus, Makro-Planar 2/100 Classic, Apo-Sonnar 2/135 Classic
DANATTHEROCK
Aug 03, 2010 02:06 |  #2
Poe wrote in post #10651856 (external link)
I was in the same boat as you a few months back and choose the Feisol. Take a look at them on the link in my signature and compare specs to what you are currently looking at. Top shelf product and I am most impressed. Especially suitable if you travel alot or just want something that is lightweight and easy to carry around.
-Dan
Canon 5D Mark II & 50D with 17-40, 24-105, 100-400, 50 f/1.4, 100 f/2.8 macro, and 1.4TC
FEISOL CT-3442 (ARL) tripod w/ Photo Clam 40-NS ballhead:lol:
DisrupTer911
Aug 03, 2010 12:04 |  #3
How tall are you?
That should be a big determining factor in tripod purchase. You don't want to spend several hundred dollars only to have to stoop over every time to use it and get discouraged.
www.vividemotionphotograph​y.comexternal link
ben_r_
-POTN's Three legged Support-
Aug 03, 2010 12:52 |  #4
If you truly want to do that, then start at the top and get the Gitzo. There is literally nothing better and you will never regret it!
2mnycars
Aug 03, 2010 14:00 |  #5
There's lots of good advice here. But if you want more, IIRC Thom Hogan has suggestions about buying the right tripod and head on his site.
edit: Found it!
http://www.bythom.com/​support.htm (external link)
Hope this helps.
Dave
Lowner
"I'm the original idiot"
Aug 03, 2010 14:07 as a reply to  @ ben_r_'s post |  #6
Unlike a previous post, I don't believe height is important when choosing a tripod. I am 6ft 2" but often find myself kneeling at the tripod because its the subject and composition that is all important.
Tripods are a very personal choice. Gitzo have a well deserved reputation for quality but I decided against one because at the time they only offered that cheap looking hammer paint finish and twist locks, which I have a pet hate of. If you like the look of them and can afford it, they are one of the best.
I chose a Manfrotto 055PROB mainly because they use snap locks and a black anodised finish. In other words, they were everything Gitzo was not!If I was choosing now I'd go for a carbon 'pod for "added lightness". I have removed the centre column and ditched it, both to improve stability and weight.
Richard
2mnycars
Aug 03, 2010 14:07 |  #7
And trying to help further...pick a tripod that is high enough without extending the centre column.
If stability becomes a problem with the tripod you've chosen, hang a heavy weight like a camera bag or pack below the bottom of the centre column. It's easier to do if you put a hook there....for future.
Dave
DANATTHEROCK
Aug 03, 2010 16:52 |  #8
2mnycars wrote in post #10654902 (external link)
Agreed. I am 6'6" and choose the Feisol in my signature for this very reason. Rock solid, compact, light, goes to the ground for macro since there is no center column. Just a perfect tripod for me.
JohnJ80
Aug 03, 2010 17:18 |  #9
Gitzo and Manfrotto are owned by the same company. Manfrotto is the more value priced line and with that comes higher weight. Gitzo is pretty much the gold standard in CF tripods. In fact, I don't think the Manfrotto is CF - they call it "mag fiber" whatever that is.
With no other criteria given, and the opportunity to spend the OP's money, Gitzo is the best choice.
J.
Obsessive Gear List
"It isn't what you don't know that gets you in trouble; it's what you know for sure that isn't so." - Mark Twain
René ­ Damkot
Aug 04, 2010 05:29 |  #10
DisrupTer911 wrote in post #10654138 (external link)
How tall are you?
Never understood this.
Maximum height of the tripod only matters if you shoot BiF or something similar where the height of the camera has no influence on the image.
Otherwise, the subject should determine camera height IMO.
A long tripod is very nice to have if you do a lot of group shots for instance. You'd need a step to be able to look in the viewfinder then ;).
If you shoot a lot of macro, max height might not be that important.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Lowner
Aug 04, 2010 05:40 as a reply to  @ René Damkot's post |  #11
Manfrotto choose the word "magfiber" (poor spelling I know), to emphasise the fact that the metal castings are made using a magnesium alloy which is supposed to be lighter than traditional aluminium alloy. The "fiber" is the normal carbonfibre.
Richard
2mnycars
Aug 04, 2010 11:58 |  #12
One of my favourite tripods is a Benbo.
Best I've used for landscapes--adjusts for rocky terrain very easily. Legs are inverted, and sealed if you put them in water up to the first joint height.
Heavy-ish though. Not CF.
Holds the camera steady.
Rene (sorry for spelling) you're right--image controls the camera height. My perception--don't use centre column comes from wearing out my first cheap tripod that wasn't very high to start, and was quite shaky with the centre column extended.
Chose my current tripod for studio use and cost. It's a lousy choice today (no studio use.) It's very heavy, and very tall.
Dave
Darkwand
Aug 16, 2010 22:27 |  #13
DANATTHEROCK wrote in post #10655908 (external link)
Cool I'm 6' 9,5" or 207cm like we say here and i got a crappy tripod currently because i want one that will fit me and not something I'll replace in 6 months.
How high is the Feisol one you're using?
Adrian My Flickr (external link)
Canon 5D MkIV, Canon 6D, Canon 7D, Canon 18-55mm 3.5-5.6 IS, 17-55mm f/2.8 IS USM, 50mm f/1.4 USM, 85mm f/1,8 USM, Sigma 70-200mm HSM Macro, 10-20mm f/4-5,6
Manfrotto 055 CXPRO4 + 498RC2, Manfrotto 410 Junior, Elinchrom: RX1200, 2x BRX250 , Dlite-it 4 and 2, Canon 580EXII
tvphotog
Aug 17, 2010 06:59 |  #14
Gitzo's have a lifetime warranty, if that's important to you. I have a travel 1541t, and that was a factor over the Feisol for me.
Jay
Ireland in Word and Image (external link) Jay Ben Images (external link)5D IV | 5DS/R | Sony RX100 V | 24-105L | 100-400 IIL | 16-35 f/2.8 IIL | 24 T/S f /3.5L II | 17 T/S f/4L | 50mm f/1.2L | 35mm f/1.4L | 70-200 f/2.8L II | 580 EX II | 600 EX-RT | Feisol 3441T/Markins Q3T lever QR | Gitzo 3542L Markins Qi20 BV-22 | Gitzo 5561T RRS MH-02
Ralph ­ Merlino
Aug 17, 2010 07:08 as a reply to  @ tvphotog's post |  #15
Gitzo really is the best. I have owned
mine for over 35 years and no trouble.
3,509 views & 0 likes for this thread, 11 members have posted to it.
Tripod Decision
1503 guests, 136 members online
