Thread started 03 Aug 2010 (Tuesday) 09:12
Stupid question time - Filter Step Down or Up Ring?
spotz04
Aug 03, 2010 09:12 |  #1
I want to use a filter with a 58mm thread on 52mm lens. Is this what I should be looking for? Or do I have it backwards?
http://www.bhphotovide​o.com …mm_Step_Up_Ring​_Lens.html (external link)
This should be freakin' easy to figure out but for some reason I can seem to wrap my brain around it this morning! :o Need more coffee...
Beachcomber ­ Joe
Aug 03, 2010 09:16 |  #2
That is the correct item. Step up rings are used to put a larger filter on a smaller lens.
Mike ­ K
Joined Apr 2001
Aug 03, 2010 12:03 |  #3
Yes that is the correct step up.
Would you consider spending just a bit more for a B&W (brass) or Tiffen equivalent? My experience with the Chinese General (Bower) brand is that the step up very frequently jams onto the lens thread or onto the filter, or both. I went though several 72-77 Bowers step ups that I could never get on to my lens. I think the tolerance for machining the threads in the Bowers is just not close enough for comfort.
http://www.bhphotovide​o.com …52mm_to_58mm_St​ep_Up.html (external link)
Mike K
Canon 6D, 1DmkII, IR modified 5DII with lots of Canon L, TSE and Zeiss ZE lenses
spotz04
Aug 03, 2010 12:21 as a reply to  @ Mike K's post |  #4
Thanks for setting me straight!
I actually ended up ordering Adorama's generic step up ring since I was also ordering the B+W K CPL filter at the same time. I hope theirs are ok or little better?
http://www.adorama.com​/FLU5258.html (external link)
600 views & 0 likes for this thread, 3 members have posted to it.
2827 guests, 161 members online
