I've seen the news and have read horror stories on several forums with people's equipment being stolen during an engagement, more likely weddings. I suggest using the Targus Defcon 1
. Although you won't need to secure it to an immovable or difficult to move object, the motion sensor would help. I use it to help secure my golf clubs when I'm away from them. I put the rain cover over my clubs, then wrap and tighten the Defcon 1 cable around the rain cover. So if anyone tries to quickly run away with my clubs, the alarm will go off. You could probably do the same with your equipment. Just wrap the Defcon 1 cable around your bag and lock it. Or use a regular lock to lock the bag, then wrap the Defcon 1 cable around the bag and through your other secured lock. And for even better security, befriend the band/DJ and keep your equipment up on the table or close to their equipment. So your gear can easily be seen, as by others. And having the Defcon 1, if someone still tries to grab & run with your equipment, the alarm will go off.
