Can the 40D go pass 30 second exposure? If not, do you know which can?
blueskyyy Member 198 posts Likes: 2 Joined Jan 2009 More info | Aug 04, 2010 22:14 | #1 Can the 40D go pass 30 second exposure? If not, do you know which can? http://www.flickr.com/photos/minhie/
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Aug 04, 2010 22:20 | #2 The longest internally timed shutter speed is 30 seconds. You'll have to put the camera's shutter speed into the "Bulb" setting and use a lockable remote switch to make any longer exposures. Skip Douglas
Aug 04, 2010 22:30 | #3 SkipD wrote in post #10664206 The longest internally timed shutter speed is 30 seconds. You'll have to put the camera's shutter speed into the "Bulb" setting and use a lockable remote switch to make any longer exposures. A lockable remote switch? Meaning a remote in general right? So basically, if i buy a remote, I switch it to "Bulb" mode on the camera, hold the shutter speed for how long I want on the remote to get over 30 seconds of exposure correct? http://www.flickr.com/photos/minhie/
tkbslc Cream of the Crop 24,604 posts Likes: 44 Joined Nov 2008 Location: Utah, USA More info | Aug 04, 2010 22:32 | #4 Yes, in the bulb shutter speed the shutter will stay open as long as the remote button is held. Most come with a button lock to hold down the button for you. Taylor
Aug 04, 2010 22:37 | #5 |
sleibrand Senior Member 635 posts Joined Jun 2007 Location: Ohio More info | Aug 04, 2010 22:47 | #6 I believe the Canon Timer Remote (TC-80N3) will do timed exposures - it looks like you can set the exposure up to 100 hours. Canon Gear: 5D3, 6D, 7D, 20D, 16-35 II, 24-105, 70-200 f2.8 IS II, 35L, 50 f1.4, 50 f1.8, 50 f2.5, 85 f1.8, 400 f5.6, 1.4x, 600EX (x2), ST-E3
Aug 04, 2010 22:52 | #7 sleibrand wrote in post #10664357 I believe the Canon Timer Remote (TC-80N3) will do timed exposures - it looks like you can set the exposure up to 100 hours. Not sure about the 3rd party timer remotes - may be worth a look if you're doing really long shots. I have another issue here. I own a Canon RS60E3 remote cord.. but the plug doesn't FIT in my canon 40. seems like there is an adapter that I need. I been searching online for what it looks like.. I could use some help in what it looks like and where I can buy it.. thanks in advance. http://www.flickr.com/photos/minhie/
tkbslc Cream of the Crop 24,604 posts Likes: 44 Joined Nov 2008 Location: Utah, USA More info | Aug 04, 2010 22:56 | #8 blueskyyy wrote in post #10664377 I have another issue here. I own a Canon RS60E3 remote cord.. but the plug doesn't FIT in my canon 40. seems like there is an adapter that I need. I been searching online for what it looks like.. I could use some help in what it looks like and where I can buy it.. thanks in advance. Yeah, those only work on the Rebels. Canon decided the higher end models needed a much "better" remote so you get to pay $60 for the RS80E3 (which is the same thing in a bigger case with a special plug) or get an ebay generic. There aren't any adapters, sadly. Taylor
Veemac Goldmember 2,098 posts Likes: 1 Joined Apr 2009 Location: Arizona, USA More info | Aug 04, 2010 23:22 | #9 blueskyyy wrote in post #10664377 I have another issue here. I own a Canon RS60E3 remote cord.. but the plug doesn't FIT in my canon 40. seems like there is an adapter that I need. I been searching online for what it looks like.. I could use some help in what it looks like and where I can buy it.. thanks in advance. I'm not sure what it looks like or where to buy it, but the port on the 40D is an "N3" port, as opposed to the "E3" port on the Rebels. I don't know how much the adapter might cost, but the POTN Support Shop sells a wired remote
Aug 05, 2010 00:09 | #10 Veemac wrote in post #10664569 I'm not sure what it looks like or where to buy it, but the port on the 40D is an "N3" port, as opposed to the "E3" port on the Rebels. I don't know how much the adapter might cost, but the POTN Support Shop sells a wired remote wow, great.. thanks for the help guys. http://www.flickr.com/photos/minhie/
| Latest registered member is Monkeytoes 1382 guests, 178 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
