Hi all,
Like many of you I have been trying to come up with the perfect diffuser for my macro work. At the moment I am experimenting with, what I like to call, the peanut diffuser. Because it was made from a plastic container which contained peanuts.
I have taken some test shots with this diffuser, without a diffuser and with (a variation on) the coke can diffuser, so you can judge for yourself.
The peanut diffuser:
First of all, the credits for this type of diff. go to the (most excellent) Swedish macro photographer John Hallmén
. I'm a big fan of his work and as far as I know he was the first one to come up with this.
Here's what mine looks like:
It's basically just a plastic container with a plastic lid transformed into a beauty dish type diffuser.
I have lined the inside of this with aluminum foil and placed an inverted V in the middle of it (number 2 in next image) . A hole was made in the bottom of the container and I atached a snoot like smaller plastic container (made from the plastic sheets used for overhead projectors, you can get them in any office supplies store) in there. This container (number 1 in next image) fits my flashhead and makes sure that my flash is always inserted into the diffuser in the same angle and same distance.
I have lined the outside with a material called 'skai', (imitation leather) which is strechtable, cheap as chips, water resistant, and looks nice as well.
It helps to strengthen the container too.
I have cut an oval piece (from the plastic sheets) that fits in the inside of the lid of the container. In between the lid and this sheet is a piece of paper towel. This way the paper towel is less likely to tear when I stick my diffuser into a plant (you don't want to know ho often that has happened to me) or when dewdrops from that same plant wet the towel and make it desintegrate on the spot.
The advantage of the the inverted V (also made from clear platsic sheet and reflective material glued to it) is that it splits the beam from your flash and sends the light bouncing around the container. The brightest light will exit the container on the left and right side, so the flash output will look like this:
Reminds you of something? Looks a lot like that big light the dentist hangs over your face huh? Because of the V and the bouncing inside light gets out send in every direction which helps to diffuse, the paper towel adds to this, and the less bright spot in the middle helps to reduce glare on your subject.
Note: Obviously a diffuser like this works best when it is as close to your subject as possible. so, important rule for macro photography: the further away your flash,the less attractive the light will be..
(continued in next post)
