Thread started 05 Aug 2010 (Thursday) 11:34
400 5.6 Vs 100-400L With 1.4x and pins taped. Anyone have experience?
Coppatop85
Aug 05, 2010 11:34 |  #1
I know these two lenses have been debated to death, and there are definitelty benifits to both. As far as I can tell based on my reading here, the AF speed and sharpness is better with the 400 5.6, but the 100-400 has IS and versitility. I am curious as to how these lenses perform with a 1.4x T-con attached with taped pins, specifically on a 7D. I am going to pick up one of these lenses, because I have wanted to "get long" for a while now, and these are the only two really in my price range. I have a 1.4x T-con, and am very curious as to how the AF speed is with both of these lenses -- Is it manageable? Or would you not bother at all?
Many thanks.
5D3, lenses, tripod, and a flash.
Wobsite: www.coppatopphotos.com (external link)
JWright
Joined Dec 2004
Aug 05, 2010 12:27 |  #2
I can't speak to how the 100-400 +1.4x performs on the 7D as I don't have that camera. I do know that even with the pins taped, that combination on a 20D is iffy, even in bright light. It was such a poor performer that I pretty much quit using it.
It's entirely possible it might be better on the 7D because of the improvements in the AF system on that camera.
John
tancanon58
Aug 05, 2010 12:35 |  #3
I had used 100-400L on FF body 5D2 and was amazing pictures (before I got 7d). But now I got 7D and 300 f4+1.4 extender. This is an excellent combination but you have to work hard on 7D AF to get a good results.
Bodies: 5DIII MkIII/ R5 mirrorles
Lenses: Canon RF 70-200 2.8 / Canon RF 85 1.2 DS/ Canon EF 100-400 II/ Canon RF 28-70 f2/Canon EF 85 1.2
kinghong1970
Aug 05, 2010 13:08 |  #4
just came back from B&H and when i was there, the 1-4+1.4TC did not AF on a 7D...
could it have been a bum sample?
Albert the Clumsy Ape
GEAR | FEEDBACK | REVIEW | KING OF GREENE STREET (external link) | FS: Gitzo GT1550T, Photoclam PC30N
Coppatop85
Aug 05, 2010 14:28 |  #5
kinghong1970 wrote in post #10667782 (external link)
It wont AF unless you tape the pins.
kinghong1970
Aug 05, 2010 14:55 |  #6
Coppatop85 wrote in post #10668236 (external link)
aaah... same for 2x?
Coppatop85
Aug 05, 2010 15:14 |  #7
kinghong1970 wrote in post #10668398 (external link)
I actually don't know about the 2x, I know you definitely will need taped pins or it wont work, however, I'm not sure if even a 2x would work. When I hear of people referring to taping the pins, it is almost always done with a 1.4x TC.
sandpiper
Aug 05, 2010 15:36 |  #8
Yes, even more so.
The problem is that the camera needs faster than f/5.6 to AF. The 1.4x makes the lens f/8 so too slow for AF to work, change it for a 2x and you are wide open at f/11 and even a 1D cannot AF at that.
It is possible to tape the pins and fool the camera into trying to Af, but it is likely to be slow and hunt quite a bit, if it can focus at all. I have always used manual focus when using the 100-400 with a 1.4x on.
I wouldn't recommend a 2x on the 100-400, it doesn't take converters well and the IQ will take quite a hit.
Primes usually work better with TCs than zooms, so I would imagine (never tried it as I don't have the prime) that the 400 f/5.6 prime will give better results, IQ wise, than the zoom. I suspect that the AF wouldn't perform any better though.
moeronn
Aug 05, 2010 15:41 |  #9
I've tried using a Tamron 1.4x (it doesn't report to the camera) with 100-400 on 7D. AF would not work at all with center point, but somewhat worked with other AF points but very slow. In the end, it was just too much of a hassle to bother.
bobbyz
Aug 05, 2010 17:17 |  #10
I use to use tamron non reporting 1.4xTC on both 100-400L and 400mm f5.6. This was on 30d. Af was slow but picture quality wasn't bad, better on 400mm f5.6 compared to the zoom.
Surprisingly 1.4xTC worked better on rebel series. A friend had rebel and she could AF when using 2xTC with one the horizontal points. This with 400mm f5.6.
Fuji XT-1, 18-55mm
johnf3f
Aug 05, 2010 17:50 |  #11
I have both the 2x & 1.4x Canon converters (and until recently the cheapie Kenko 1.5), with pins taped I got pretty mediocre results. Funnily enough the £50 Kenko wasn't bad and does allow af on an XXD body (20d in my case) with the 100-400. Af was not too bad on static subjects - slow ponerous but usually accurate. However with my current gear I find I get better pictures by cropping rather than by using converters ie if it's larger than the (indicated) af point in the viewfinder it will do a passable A4 print and a good A5, perhaps that's the 1d mkiv or perhaps I have become more critcal?
Try cropping vs converters - you may be (pleasantly) surprised!
P.S. Not used the 400 f5.6 but I hear it's excellent - used the 100-400 for 5 years - the most veratile lens you can get! Still sold it for my 300 F4.
Life is for living, cameras are to capture it (one day I will learn how!).
DegasGoneDigital
Aug 05, 2010 19:03 |  #12
The 400 prime and the 7D would be a great combo. I would not tape pins, with the 7D You can crop a lot with great results.
-Sam.
R6 / EOS R
8-15 fisheye, 16-35 F4 IS, 24-70 F2.8 II, 100 F 2.8 IS Macro,
100-400 IS II , 500 F4 IS II, 1.4TC III.. 2.0TC III...
http://www.flickr.com/​photos/degasgonedigita​l/ (external link)
phreeky
Aug 05, 2010 22:53 |  #13
I've posted these elsewhere but will again due to relevance. These are all with AF using 400 F/5.6 + 1.4x (kenko pro with pins taped).
All wide open using AI Servo on a 20D. I find that borderline AF combos, such as when you need to tape pins, typically work better in AI Servo. For static subjects I also use servo mode but I have a button assigned to prevent AF (some people use the opposite - only AF when using the button, either setup should be fine), and I give the shutter a tap to get into focus and then manually adjust a touch if it appears to need it.
A non-reporting 2x CAN AF, but it's about as reliable as a British car.
As for IQ, this is a somewhat cropped image from the 400 with both a 1.4x and 2x TC. Most of the image degradation is from having to use such a high ISO:
bobbyz
Aug 05, 2010 23:05 |  #14
You guys want to see what cheap tamrom 1.4xTC on 400mm f5.6 can do then look at pbase gallery of Daniella. Here is the link:
http://www.pbase.com/z​ylen/birds (external link)
She even does BIF and at the time she was using just a rebel if I remember correctly.
Fuji XT-1, 18-55mm
RPCrowe
Joined Nov 2005
Aug 06, 2010 00:02 |  #15
That would have been one nice addition to the 7D... auto focus capability at f/8! With the improvements in auto focus capability on the 7D, I was quite disappointed that they didn't include that one last missing piece of the puzzle.
3,002 views & 0 likes for this thread, 11 members have posted to it.
1384 guests, 179 members online
