Thread started 07 Aug 2010 (Saturday) 17:41
Will a 580EXII fill the large PCB PLM
imahawki
Aug 07, 2010 17:41 |  #1
Title says it all. I'm going through a lot of scenarios as I contemplate going to all hotshoe strobes. I already have the large PLM that I was using with my Genesis strobes. Does anyone know if the 580EX will fill it?
Olympus OMD E-M10 | Olympus 25 f/1.8 | Olympus 45 f/1.8 | Olympus 75 f/1.8 | Olympus 9-18 f/4-5.6 | Olympus 14-42 f/3.5-5.6 | Olympus 40-150 f/4-5.6
My Zenfolio Gallery (external link)
BrassPremier
Aug 07, 2010 18:53 |  #2
i dunno. from the looks of it, you pretty much need a strobe without any sort of reflector/modifier, so it shoots out 180*, to hit everything.
http://www.flickr.com/​photos/brasspremier/ (external link)
imahawki
Aug 07, 2010 21:19 |  #3
Thanks. I tried it and I think you're right. I pulled out the diffuser to force it to 14mm zoom and then took a picture of the PLM and it didn't look like it was filling it.
ootsk
Joined Jan 2002
Aug 08, 2010 00:19 |  #4
It's the wrong tool for the job. Even if you did get some decent range, it would overwork the flash.
Speedlighter
Aug 08, 2010 00:39 |  #5
ootsk wrote in post #10680779 (external link)
Does a flash some how overheat or put under extra strain when placed in a oversized modifier? I'm confused :confused:
Shenanigans
Aug 08, 2010 00:44 |  #6
No, it will fire at full power, which it was designed to do. The flash can't fire at "more than full". Just follow Canon's recommended flash interval and cooling periods and shoot at full as much as you want to.
OWSIU
Aug 08, 2010 03:01 |  #7
Here's a nice write up from Rob about the 580EX II and 64" PLM:
http://www.robgalbrait​h.com …p?cid=7-10046-10396-10407 (external link)
It doesn't sound like the 580EX II can fill the 64", so the 86" is highly unlikely. But with the PLM, softness is much better with very minimal impact on efficiency.
TMR ­ Design
Joined Feb 2006
Aug 08, 2010 05:26 as a reply to  @ OWSIU's post |  #8
Not only won't it fill the PLM completely or evenly but it's such an anemic setup. If you want to use Speedlight's with a modifier that large you're going to have to use multiple Speedlight's and spread them out so they're not clustered so tightly around the axis of the umbrella.
A DIY or something like the Lastolite tri-flash might do it.
Robert
imahawki
Aug 08, 2010 10:09 |  #9
thanks guys... not looking to jump through hoops to make it work, if it won't, I'll probably look into selling it.
2,855 views & 0 likes for this thread, 7 members have posted to it.
Latest registered member is RawBytes
1412 guests, 161 members online
