I'd go with the kit lens, as wide as possible. At 50mm your chances of capturing a meteor are reduced massively.
That should be about right.
Personally I'd open it up a bit more. I usually open the aperture fully, and then close down two or three stops.
Punta Cana Bride wrote in post #10684211
30 second exposures or more (how do I do this?)
use maual mode with shutter speed set to bulb
That's how you expose for longer than 30s. Bulb setting, then lock your remote shutter. It'll expose for as long as you keep the remote shutter locked.
keep lens at infinity focus in manul mode
Don't focus the lens right out to "infinity", as it'll go past infinity and your stars/meteors will be a bit blurred. Try and manually focus on a really bright star, and then leave it at that.
Can this be done without a cable release (remote shutter release)? I have never done this before.
Ah, it's preferable if you do have a cable release, but not vital. If you don't have one, forget Bulb mode for starters and set it to 30-second exposure, then turn on the timer to 2-seconds. That way, when you press the shutter, the camera has 2 seconds to lose any vibrations before taking the shot. As soon as the shot's finished, preview it and see how it looks. If everything's a bit too dark, up the ISO and maybe open the aperture a bit. If it's too light, drop the ISO or close the aperture a bit. Once you're happy with the way a shot looks, take as many as you can I would say. You're bound to capture a meteor or two in there somewhere.
Really though, get a remote shutter release if you haven't got one, they make life so much easier!
