Taken durring our daily afternoon thunderstorm at Houston IAH. An ExpressJet EMB-145XR waits to depart....
Aug 12, 2005 01:35 | #1 Taken durring our daily afternoon thunderstorm at Houston IAH. An ExpressJet EMB-145XR waits to depart.... -Chris
Aug 12, 2005 01:41 | #2 This one might be a good B&W candidate. Anyone wanna tell me how to do the conversion properly? -Chris
Dew Senior Member ![]() 395 posts Joined Apr 2005 Location: UK More info | Aug 12, 2005 01:44 | #3 Like it! Interesting sky. EOS 1D MkIV | EOS 40D | BG-E2N | EOS 30D | BG-E2 | EF 50mm f/1.4 USM | EF-S 17-55mm f/2.8 IS USM | EF 16-35mm f/2.8L II USM | EF 70-200mm f/2.8L IS USM | EF 300mm f/4L IS USM | EF 400mm f/4 DO IS USM | Extender EF 1.4x II | Tamrac Model 5575 Expedition 5
Bryan Allman Junior Member 27 posts Joined Nov 2002 More info | embdude wrote: This one might be a good B&W candidate. Anyone wanna tell me how to do the conversion properly? in: Elements 2.0 / Digital Photo Pro I know I can just desaturate, but I think that is also not the proper way..... Here's a quick conversion
and a bit of Photoshop to remove the runway indicator board Regards
Croasdail making stuff up ![]() More info | Aug 12, 2005 06:28 | #5 nice shot. I like the color - but since you asked in PSE I use Image -> Adjustments -> Gradient Map. Another is to go into "adjust color" and removing it - though they generally turn out very neutral. Finally you can do like above and go into "Enhance -> adjust color -> hue/saturation ->desatrate individual color channels" as well - but for a quick an easy - the first method works for me 95% of the time.
Croasdail making stuff up ![]() More info | desaturate and then gradient map - the difference are very subtle but very identifiable in larger images... plus for what ever reason which I don't fully understand - they all look different posted then they do in the original PSE version.... go figure. Cheers.
Ok here is my very first B&W from color attempt! -Chris
I have reworked the original color image too. Basically I made the B&W version a layer and gave it about 50% opacity.... Let me know what you think, Thanks... -Chris
Croasdail making stuff up ![]() More info | Aug 12, 2005 13:10 | #9 It gets a little dark on the far edge - but man - does that bring out the contrast levels alot - very nice. I 'll have to try that sometime.
Bryan Allman Junior Member 27 posts Joined Nov 2002 More info | embdude wrote: Ok here is my very first B&W from color attempt! Bryan, thanks for the motivation. I have been looking here: http://www.digital-monochrome.com/index.htm ![]() and trying to get results like his... I also dont know how to clone things out on elements! Guess I need to learn that too! Photoshop is a steep learning curve - but it has a great 'step back' facility for when you mess it up !!
y 1600 |
Log in Not a member yet?
Latest registered member is Dannal01 860 guests, 189 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 |
