Hi
I want to mail an 8x10 that I printed on my inkjet. Is there a special way to package it that will keep it protected? Or just throw it in a full size envelope?
Stefan
StefanA "The D is supposed to be where the S is!" More info | Aug 09, 2010 17:34 | #1 Hi 80D, Canon 17-55mm f/2.8, Canon 18-135mm f/3.5-5.6, Canon 50mm f/1.4, Canon 70-200mm F/4L,Tokina 11-16 f/2.8, Canon 100-400 f/4.5-5.6, Kenko 1.4 TC, Canon 580 exII Speedlite, ebay wireless trigger, Genesis 3 light kit
numbersix fully entitled to be jealous 8,964 posts Likes: 109 Joined May 2007 Location: SF Bay Area More info | Aug 09, 2010 17:37 | #2 If you want to be sure it doesn't get folded you can slip a piece of 1/4" plywood into the envelope along with the photo. "Be seeing you."
Aug 09, 2010 18:07 | #3 Thanks for the input. Yeah, I am not THAT anal about it 80D, Canon 17-55mm f/2.8, Canon 18-135mm f/3.5-5.6, Canon 50mm f/1.4, Canon 70-200mm F/4L,Tokina 11-16 f/2.8, Canon 100-400 f/4.5-5.6, Kenko 1.4 TC, Canon 580 exII Speedlite, ebay wireless trigger, Genesis 3 light kit
numbersix fully entitled to be jealous 8,964 posts Likes: 109 Joined May 2007 Location: SF Bay Area More info | Aug 09, 2010 19:03 | #4 Stefan A wrote in post #10690293 Thanks for the input. Yeah, I am not THAT anal about it . It's just going to my mother. But you gave me a good idea which is to cut some sides off of a stiff box and place the photo between. The other thing I am worried about is the ink coming off. Do you think wax paper between the photo and the cardboard would be a good idea?Stefan No. Wax paper is likely to stick to the ink. "Be seeing you."
20droger Cream of the Crop 14,685 posts Likes: 27 Joined Dec 2006 More info | I suggest you use a mailing tube. A gently rolled photo has no problem returning to flat for framing. It's creases that are the killers.
robie Senior Member 317 posts Joined Oct 2008 Location: Langley, BC More info | Aug 10, 2010 01:00 | #6 Cut two pieces of cardboard out and put one on each side of the photo.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Aug 10, 2010 10:07 | #7 If flatness is needed to be guaranteed, I would use drafting (not masking) tape to tape the print face down onto a piece of foam core which is slightly larger than the print size, and put it into an envelope with 'Photo Do Not Bend' on the outside of the envelope in big letters. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
numbersix fully entitled to be jealous 8,964 posts Likes: 109 Joined May 2007 Location: SF Bay Area More info | Aug 10, 2010 13:46 | #8 Just last Friday I came home to see my mail carrier folding a large envelope into thirds so he could cram it into my mailbox instead of walking to the door. "Be seeing you."
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Aug 10, 2010 13:59 | #9 number six wrote in post #10695539 Just last Friday I came home to see my mail carrier folding a large envelope into thirds so he could cram it into my mailbox instead of walking to the door. No harm done, but I doubt any "Do Not Bend" instructions would have mattered. -js But you could take the folded envelope to the post office and speak to the Postmaster and show him the envelope, and a photo of that same envelope stuffed into your mailbox. And have a discussion of the carrier's two-digit IQ. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Aug 10, 2010 21:51 | #10 Check out some of the mail service companies. I am pretty sure I have seen photo mailers in at least one of these stores. The mailer was an envelope with a stiffener inside and I believe it was marked PHOTO on the outside. I am not sure but it may have had the words DO NOT BEND also. However I think the mailing tube that was mentioned in a previous post is the safest way to insure a photo does not get folded. The package mailing stores probably carry those also. Joe
20droger Cream of the Crop 14,685 posts Likes: 27 Joined Dec 2006 More info | Aug 11, 2010 01:10 | #11 number six wrote in post #10695539 Just last Friday I came home to see my mail carrier folding a large envelope into thirds so he could cram it into my mailbox instead of walking to the door. No harm done, but I doubt any "Do Not Bend" instructions would have mattered. -js This is exactly why I use mailing tubes.
20droger Cream of the Crop 14,685 posts Likes: 27 Joined Dec 2006 More info | Aug 11, 2010 01:13 | #12 Sparky98 wrote in post #10698305 Check out some of the mail service companies. I am pretty sure I have seen photo mailers in at least one of these stores. The mailer was an envelope with a stiffener inside and I believe it was marked PHOTO on the outside. I am not sure but it may have had the words DO NOT BEND also. However I think the mailing tube that was mentioned in a previous post is the safest way to insure a photo does not get folded. The package mailing stores probably carry those also. They can be found at any office supply store, graphic arts store, craft store, or blueprint shop.
tkbslc Cream of the Crop 24,604 posts Likes: 45 Joined Nov 2008 Location: Utah, USA More info | Aug 11, 2010 01:14 | #13 They have 8.5x11 cardboard envelopes available at any place that sells envelopes. That is usually good enough. Taylor
Vladimer Senior Member 634 posts Likes: 14 Joined Dec 2009 Location: Alberta, Canada More info | Aug 11, 2010 17:48 | #14 Wilt wrote in post #10695602 But you could take the folded envelope to the post office and speak to the Postmaster and show him the envelope, and a photo of that same envelope stuffed into your mailbox. And have a discussion of the carrier's two-digit IQ. You can, but it is not going to get your photo unfolded or fix anything, just going to waste your time, I do it nearly daily till I am blue in the face and things don't change
20droger Cream of the Crop 14,685 posts Likes: 27 Joined Dec 2006 More info | The trouble with most mailers for all but the smaller photos is just what Vladimer said, the cramming into the mailbox. Many, many mailboxes, especially urban mailboxes, don't take large envelopes unless they are folded. What's a carrier to do?
| Latest registered member is semonsters 1465 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
