Can someone tell me how to reduce the time on the timer?
I just hate having to wait 10 seconds for my camera to take a picture when really all I need is 3 or 4 seconds to prevent camera shake.
Burodsx Member 75 posts Joined Aug 2005 Location: South Carolina, USA More info | Aug 12, 2005 19:24 | #1 Can someone tell me how to reduce the time on the timer? [If at first you don't succeed, then sky-diving is not for you.]
EpHeSuS Senior Member 280 posts Joined Jul 2003 Location: Melbourne, Australia More info | Aug 12, 2005 20:03 | #2 Use Mirror Lockup. I think it's 2 seconds then. EOS 20D | 1d Mk II | 50mm f/1.8 | Sigma 10-20 f/4-5.6 EX DC HSM | Canon 24-105 f/4L IS | Canon 135 f/2L | Sigma 100-300 f/4 EX HSM | Sigma 1.4x EX TC | Sigma 18-200 f/3.5-6.3 DC OS | 580EX II
Poco Member 233 posts Likes: 1 Joined May 2005 Location: Port Coquitlam, B.C. More info | Aug 12, 2005 20:13 | #3 Also, if you get the infrared remote it always has a two second delay. I like the mirror lockup as it also has the added advantage of reducing camera shake even more, unfortunately it is a pain to turn on and off (I wish the mirror lockup was always on when you use the timer or remote). http://notions.okuda.ca
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | If you really want to eliminate camera shake, then get a tripod.
Poco Member 233 posts Likes: 1 Joined May 2005 Location: Port Coquitlam, B.C. More info | robertwgross wrote: If you really want to eliminate camera shake, then get a tripod. ---Bob Gross--- That goes without saying. Even with a tripod the simple action of pressing the button can cause the camera to shake as can the mirror snap. To get the least movement you should use tripod + mirror lockup + timer/remote. http://notions.okuda.ca
Thanks for the info. And I have a tripod, just the point was me shaking the camera each time I press the button - thus using the timer. [If at first you don't succeed, then sky-diving is not for you.]
puttick Senior Member More info | Aug 13, 2005 06:56 | #7 You'll find that simply using the remote cable release is far more convenient than the timer, mirror lockup, or the IR remote (IMO). It also means that you can take the photo exactly when you want to, which can be a major issue - even with a camera on a tripod. Nigel Puttick
| Latest registered member is johntmyers418 1178 guests, 186 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
