Thread started 11 Aug 2010 (Wednesday) 17:29
How strong are the strap lugs on a 5D?
mike_d
Aug 11, 2010 17:29 |  #1
How much weight would you feel comfortable carrying on just one?
malam
Aug 11, 2010 17:48 |  #2
mike_d wrote in post #10703738 (external link)
Are you refering to the R-Strap ?? I use my R7 for a 5D MkII and the Canon 70-200 f2.8 L Mk II without any problems at all.
Canon 5D Mk III
EF70-200mm f2.8L IS MKII; EF50mm f1.2L; EF16-35mm f2.8L II; EF100mm f2.8L IS Macro; EF24-105mm f4.0L IS; EF200mmf2.8L II USM
mike_d
Aug 11, 2010 18:01 |  #3
malam wrote in post #10703829 (external link)
Yeah, although I'm leaning toward the Luma Loop, I'd still be carrying the load by one lug. I'm thinking of attaching the sling to the left-hand lug of the camera, then a hand strap between the L-plate's lug and the camera's right-hand lug. My heaviest lens is the 100-400 (about the same size and weight as your 70-200) and I don't want to have to screw anything into the bottom of the RRS plate on the tripod ring's.
The ­ Ran
Aug 11, 2010 20:45 |  #4
As far as I know the lugs are part of the underlying steel (?) chassis, I'd say they can probably hold anything you throw at them bar a 1200mm mounted on the body. I'd be far more worried about the strap and it's mounting hardware failing.
mike_d
Aug 11, 2010 21:32 |  #5
The Ran wrote in post #10704795 (external link)
Good to know they're part of the camera's frame and just held in by a tiny screw or something.
jack ­ lumber
Aug 11, 2010 21:41 |  #6
Mike I have wondered the same thing, Im sure Canon has a spec on how much load the lugs will hold,, off to do a quick and dirty google.
There is a fine line between "hobby" and "obsession"
5D-20D-7D gripped- all canon-28MM 1.8 - 50MM 1.8 -17-40 L -100MM 2.8 macro -70-200MM L F4- 100-40MM L -1X4 teleconverter-Sigma 20-40MM 2.8:D 580 EX 11 flash- manfrotto tripods and monopods.
Headshotzx
Aug 11, 2010 21:53 |  #7
Strap lugs are all built into the frame itself, even the bottom strap lugs of 1 series and battery grips.
If anything, most quick releases and straps will snap and fail before the lugs give way unless they are tampered with imo.
Zexun | Flickr (external link) | YouTube (external link) |
1,548 views & 0 likes for this thread, 5 members have posted to it.
2653 guests, 167 members online
