Thread started 12 Aug 2010 (Thursday) 10:37
scanning photos
morpheus6d9
Aug 12, 2010 10:37 |  #1
I'm designing a website for a friend he is a tattoo artist he took the majority of his photos using film what is the best way to scan the photos ?
thanks
50D | 60mm f/2.8 macro |Tokina 12-24 f/4 | Nifty-Fifty | SB-20 | 580 EXII
gjl711
Aug 12, 2010 10:46 |  #2
Negatives? Slides? 4x5s?
Best way is to get the best scanner for the job. If you have negatives or slides a film scanner works best. If they are prints, a good quality drum scanner is the best way, but those beasts are expensive.
For one more budget minded, a good flatbed scanner with film capability is the way to go. Check out the Canoscan 8800 or 9000 (external link) works well as does the Epson V500 (external link).
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
NinetyEight
"Banned for life"
Aug 12, 2010 11:08 |  #3
A drum scanner for a web site image is a bit over the top IMO :-)
For prints a typical flatbed will do the job, for transparencies or negatives a slightly more expensive model will also do 35mm film.
Kev
ChasP505
"brain damaged old guy"
Aug 12, 2010 13:25 |  #4
morpheus6d9 wrote in post #10707997 (external link)
...what is the best way to scan the photos ?
I use an old and inexpensive Epson Perfection 2480 Photo. It has an adapter for scanning 35mm slides and negatives. I get very good results.
I always scan in 48-bit color at 600dpi. With a slide or film, 600dpi is good enough for web images or small prints. I turn all adjusts, auto or manual, off in the scanner software, preferring to do all adjustments in Photoshop. In Photoshop, I save as a 16bit TIFF in Adobe RGB and edit. (But if the source of the scan is a very good photo or slide, 8 bit is perfectly fine.) The final image output will be converted for size, bit depth, color space, as needed.
Chas P
MikeThompson
Aug 15, 2010 18:15 |  #5
Chas, When scanning at 600 dpi, how large a print can you make with good results?
Mike
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and proclaiming....."WOW, WHAT A RIDE".
tonylong
...winded
Gallery: 60 photos
Aug 15, 2010 18:55 |  #6
The output of the scan will depend on the quality of the original print and of the scanner itself. If you can take the file and enlarge it to, say, 100% and it looks decent (after maybe applying some sharpening) then it should give a "good" print at 300 ppi (double the length and width of the original print) and you can try a lower resolution such as 200 ppi.
I've found, though, that printing scans of prints does tend to break down when printing, say, an 8x10 but that was in the "old days" of scanners -- the early '90s when scanners didn't have as high resolutions as they have achieved over the years and when inkjet printers were in their infancy and also didn't have the resolution they now have.
Do your scanning and print some tests and judge for yourself! I would think it would be great to have say a good quality 11x14 or 11x17 print from a 35mm shot whether scanned or directly printed.
Tony
ChasP505
Aug 15, 2010 21:11 |  #7
dreamcatcher1450 wrote in post #10727070 (external link)
When scanning a 35mm slide, you can easily print an 8x12 or larger at 300ppi. If scanning a print, YMMV depending on the size of the print.
More important is scanning in 16 bit mode. After editing the scan, you can convert to 8 bit and save as a JPG.
Chas P
1,758 views & 0 likes for this thread, 6 members have posted to it.
scanning photos
1499 guests, 139 members online
