I been hearing about ND filters, what excactly would one use one for? and how?
Also what number would you need?
Aug 13, 2010 12:05 | #1 Permanent banI been hearing about ND filters, what excactly would one use one for? and how?
V-Wiz Goldmember 2,255 posts Joined Sep 2009 Location: Southern California More info | Aug 13, 2010 12:07 | #2 I have the same questions. Gripped 5D Mark II l 24-105 F/4 L l 70-200 F/4 L l Tokina 12-24 F4 l 50mm 1.8 l Sigma 600 Mirror l B+W KSM CPL l B+W 6stop ND filter l Hitech 0.6 GND l YN-468 Flash l Kenko Pro 300 1.4 TC l Induro Tripod, Vanguard 250 Ballhead.
redhotsheep Goldmember 1,576 posts Joined Oct 2005 Location: London More info | Aug 13, 2010 12:14 | #3 Put simply ND filters are dark and neutral density (shouldn't give your images a colour cast). There are two types, ND (solid) and ND grad.
argyle Cream of the Crop 8,187 posts Likes: 24 Joined Apr 2007 Location: DFW, Texas More info | Aug 13, 2010 12:14 | #4 nekrosoft13 wrote in post #10715044 I been hearing about ND filters, what excactly would one use one for? and how? Also what number would you need? ND filters are used to reduce the amount of light reaching the sensor under strong lighting conditions. Portrait photographers rely on ND filters in order to use a large aperture in bright light for DOF purposes. Landscaper shooters use them to lengthen the shutter speed to slow down moving water (silky effect or smooth-as-glass effect). "Fat, drunk and stupid is no way to go through life, son". - Dean Wormer
Aug 13, 2010 12:20 | #5 Permanent banok, for example ND Grad, what would be a good number on very sunny day around 11-5pm?
luigis Goldmember 1,399 posts Likes: 3 Joined Jun 2008 Location: Buenos Aires, Argentina More info | Aug 13, 2010 12:41 | #6 nekrosoft13 wrote in post #10715123 ok, for example ND Grad, what would be a good number on very sunny day around 11-5pm? top of the filter would be darker, how excactly would that affect lets say a tree that is visible on horizon? Your question brings something important that is often overlooked about graduated filters: You can do the same digitally. www.luisargerich.com
rvdw98 Goldmember 1,592 posts Joined Jul 2008 Location: Netherlands More info | Aug 13, 2010 13:55 | #7 nekrosoft13 wrote in post #10715123 ok, for example ND Grad, what would be a good number on very sunny day around 11-5pm? You meter the sky and the foreground separately and determine the difference in stops (say 5 stops). You then decide what you would want the difference to be (say 2 stops). This implies using a 3 stop ND grad to cover the difference. Roy
rvdw98 Goldmember 1,592 posts Joined Jul 2008 Location: Netherlands More info | Aug 13, 2010 14:01 | #8 luigis wrote in post #10715223 Your question brings something important that is often overlooked about graduated filters: You can do the same digitally. A graduated filter is just like a gradient mask between two layers in any photo-editing software. You can take two shots with different exposures and blend them digitally using a mask, in the way you want. I prefer to spend my time in the field, instead of behind the computer. Roy
Aug 13, 2010 14:20 | #9 Permanent banrvdw98 wrote in post #10715621 You meter the sky and the foreground separately and determine the difference in stops (say 5 stops). You then decide what you would want the difference to be (say 2 stops). This implies using a 3 stop ND grad to cover the difference. Like with solid ND's, this is not a one size fits all kind of decision. It depends on the conditions and your preferences. being a noob, how do you "meter" stuff seperatly
rvdw98 Goldmember 1,592 posts Joined Jul 2008 Location: Netherlands More info | Aug 13, 2010 14:24 | #10 nekrosoft13 wrote in post #10715797 being a noob, how do you "meter" stuff seperatly Using your camera's light meter. Either zoom in to separate parts of the scene, or use the spot meter setting if available. Roy
Young_Werther Member 139 posts Joined Apr 2010 More info | Aug 13, 2010 14:54 | #11 Anyone have a preferences to what ND filter they like to use? Canon 50D, 50 1.8, 135L 2.0
PhilF Cream of the Crop 5,737 posts Likes: 609 Joined Jan 2010 Location: Valencia, CA More info | Aug 13, 2010 15:40 | #12 nekrosoft13 wrote in post #10715797 being a noob, how do you "meter" stuff seperatly you point it ... take note of the numbers... then point it to the next one. http://philfernandezphotography.com
rvdw98 Goldmember 1,592 posts Joined Jul 2008 Location: Netherlands More info | Aug 13, 2010 16:24 | #13 Young_Werther wrote in post #10715953 Anyone have a preferences to what ND filter they like to use? Brand, type or density? Roy
V-Wiz Goldmember 2,255 posts Joined Sep 2009 Location: Southern California More info | Aug 13, 2010 18:16 | #14 So once you have those numbers down which shutter speed and Aperture do you use since you have two different field. What do you shoot at. Gripped 5D Mark II l 24-105 F/4 L l 70-200 F/4 L l Tokina 12-24 F4 l 50mm 1.8 l Sigma 600 Mirror l B+W KSM CPL l B+W 6stop ND filter l Hitech 0.6 GND l YN-468 Flash l Kenko Pro 300 1.4 TC l Induro Tripod, Vanguard 250 Ballhead.
luigis Goldmember 1,399 posts Likes: 3 Joined Jun 2008 Location: Buenos Aires, Argentina More info | Aug 13, 2010 18:18 | #15 Young_Werther wrote in post #10715953 Anyone have a preferences to what ND filter they like to use? For solid NDs I use a Hoya ND400 (9 stops) and a couple of ND8 (3 stops). Stacking I can go 3,6,9 or 12 stops. www.luisargerich.com
| Latest registered member was a spammer, and banned as such! 2653 guests, 167 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
