Thread started 15 Aug 2010 (Sunday) 11:14
1D Mark III sub-mirror fix?
mnez17
Aug 15, 2010 11:14 |  #1
Just picked up a 1D Mark III which was in the impacted serial # range. Focus is fine and no error messages but trying to decide if I should send it in for the sub-mirror recall. Hesistant about sending it in since there are no know issues. Any idea of how long Canon will be honoring this recall. The loaded Firmware is 1.2.3.
Canon 1D Mark III|Canon 40D| Canon 350D| Opteka Battery Grip| 430EX| EF 85mm f/1.8 USM| EF 70-200mm 2.8L USM|EF 300mm IS 2.8L|EFS 17-55mm IS USM 2.8 |Kenko 1.4X
A.L. Sports (external link)
MaxPreps Profile (external link)/Sports Shooter (external link)
ed ­ rader
"I am not the final word"
Aug 15, 2010 11:18 |  #2
mnez17 wrote in post #10725235 (external link)
i sent three of our four bodies in for the fix tho none had problems before or after. i'd say send it in if you have the time.
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
mnez17
Aug 15, 2010 11:49 |  #3
ed rader wrote in post #10725251 (external link)
ed rader
Thanks Ed. Yeah, might as well do it now before collegiate and high school football starts here in the North East.
Hamfist
Aug 16, 2010 10:07 |  #4
A just sent my 1dIII in to the Canon service center in NJ. Sent it in via FedEx 2 day on a Friday and got it back the following Thursday. Very quick turnaround right now.
Film, suckers.
sdipirro
Aug 16, 2010 11:21 |  #5
Also note that while Canon initially published a serial number range, they subsequently published a list of serial numbers, in the range, that did not need the mirror fix. My 1d3 happened to be on that second list, and since I wasn't having the described problems, I never bothered to send it in.
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
mnez17
Aug 25, 2010 08:49 as a reply to  @ sdipirro's post |  #6
Well, the Canon Service Center turnaround time was pretty quick. I sent it out on Monday and received it 7 days later. Unfortunately, it has been raining ever since I got it back.
mnez17
Aug 28, 2010 15:33 as a reply to  @ mnez17's post |  #7
Well, here are the first images taken since the sub-mirror fix and all appears well.
1)
IMAGE: http://alsports.smugmug.com/photos/985623337_AUTBk-XL.jpg
2)
IMAGE: http://alsports.smugmug.com/photos/985623054_LSVRA-XL.jpg
3)
IMAGE: http://alsports.smugmug.com/photos/985623199_gGwoX-XL.jpg
4)
(DUPLICATE IMAGE)
NeoTokyo
Aug 28, 2010 18:17 |  #8
I had to send mine into Canon-NJ 3 times.
The third time they got everything near perfect, the only thing that was off was the calibration from LV and VF. Through the VF it always underexposed slightly than through the LV even though the settings were the same, the metering was off. In rarer cases the WB is off.
Check out my flickr! http://www.flickr.com/​photos/crainracing/ (external link)
NeoTokyo
Aug 28, 2010 18:19 |  #9
I should say 3 times after the first time it went in for the fix, so 4 times total.
Ekean
Oct 07, 2010 21:21 as a reply to  @ NeoTokyo's post |  #10
I'm about to send mine in.
I notice that in the fast bursts, there are several images in the burst that are soft.
I also notice that the in AI Servo, it's not as sharp as I would like.
After the Canon fix, I'm curious to see if anyone had problems like mine and are pleased with the fix. Noticeable difference?
Nikon D3s | Nikon 20 f/1.8g | Sigma 35 f/1.4 Art | Nikon 85 f/1.8g |
sonnyc
Joined Jun 2005
Oct 07, 2010 23:48 |  #11
I just got mine back. It was in for the sub mirror fix last Nov but then I got error 99 and sent it in. They said the mirror is not working properly causing the error intermittently so they replaced it again.
I also mentioned that focus was not consistent in AI Servo and on the paper it said they adjust focus and electronics parts to factory specs.
Just send it in until it's fixed. They send you a pre paid label for shipping too.
Sonny
4,944 views & 0 likes for this thread, 7 members have posted to it.
1011 guests, 107 members online
