Thread started 16 Aug 2010 (Monday) 21:50
5DII or 7D
PeaceFire
Aug 16, 2010 21:50 |  #1
OK, I know the obvious answer to this question is the 5DII is better. I know this much and I was pretty much decided on that but my mind won't let me settle on this. So I thought I'd get your advice...
I have about $5,000 coming my way soon to upgrade my gear with. I want the 70-200mm f/2.8L IS for sure and I also need to upgrade a camera. I just cannot stand my 40D anymore. It's basically obsolete for what I need it for.
I shoot mostly weddings and prefer to shoot with only natural light so I need a camera that will help me more when the sun goes down or for darker indoor weddings. But I also need a camera that will help me with my birth photography which I'm trying to get into more. I would NEVER use flash during a birth and often mother's choose to give birth in very dim lighting. I pulled off my past births using my 5D and 50mm f/1.4, but feel I would be more successful with a camera I can crank up to 6400 (or even 12800) ISO without worrying about losing too much of the image quality.
I know, all of this is STILL pointing towards the 5DII. But here's why I'm on the fence- I also want to get more primes. I use primes during births, and for most of my portrait sessions. My 85 f/1.8 and 50mm f/1.4 I lost in my divorce. I would love to add those back into my line-up. I know I can live without them but I'd rather not have to. But if I get the 5DII I won't be able to afford them plus the 70-200. If I go with the 7D I could. So is the 7D "good enough".
Suggestions? I suck at decisions like these.
My Gear List / My Blog (external link)
tim
Light Bringer
Aug 16, 2010 22:32 |  #2
I would say 5DII, and then add primes as you can afford them.
gjl711
Aug 16, 2010 22:39 |  #3
Tough call. I have both the 5D2 and the 7D and my shooting choice is changing the more I shoot. Funny thing is that ISO is not part of the equation. The 5D does better, but it's not a whole lot better. The two things that make the decision as to which body I grab is focal length. If I'm shooting wide I grab the 5D and if I'm shooting long, it's the 7D and focus speed. The 7D focuses way faster and more precisely especially in low light. Bottom line is whichever body you choose, they both will do the job.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
nicksan
Man I Like to Fart
Aug 16, 2010 23:06 |  #4
The 5D2 will give you about 1.5 stops better high ISO performance over the 7D.
If you are a natural light shooter, even for weddings, then I'd say the 5D2. End of story really...
Used ones can be had for 2100. You may also consider the older version of the 70-200. While the new version is indeed sharper, ask yourself if clients will notice this. The older version was a workhorse up until late last year in fact. This would give you enough to buy some primes...
Red ­ Tie ­ Photography
Aug 16, 2010 23:12 |  #5
Get a 5d2 and some primes. I used to LOVE my 70-200, but since I got my 135mm I haven't put it back on my camera. I am loving primes, and while I bought them for backup gear, they are now my work horses.
Bryan
Gear List (external link)
San Diego Wedding Photography - Red Tie Photography (external link)
Red Tie Photography Blog (external link)
tdodd
Aug 17, 2010 03:44 |  #6
I do have both cameras, and a 1D3 too. I also used to use a 40D and have shot weddings with it.
Personally I'd go for the 5D2 without hesitation. If you are concerned about FOV then you always have the option to crop a 5D2 image down to APS-C size, but you can't do the reverse with an APS-C camera. You'll still end up with an 8.2MP image if you crop like that, but instead of the 7D's 18 heinously noisy megapixels you'll only have 8.2 relatively clean ones to deal with.
The only reason I'd pick the 7D over the 5D2 for the usage you describe is for the improved AF with peripheral focus points. In most other respects the IQ of the 5D2 would easily be the dominating factor in my decision making. Sure, there's stuff like the 3 stop meter, wireless off camera flash control and the more accurate viewfinder, but at the end of the day IQ is king and you can work around those other limitations.
I might add that for a wedding I'd go with my 5D2 and 24-70 plus my 1D3 and 70-200. The 7D would be relegated to backup, with a 17-55 mounted and ready to go. I'd have a couple of primes and a 16-35 lurking about as well, but I would hope not to have to use them.
Christina
Aug 17, 2010 09:20 as a reply to  @ tdodd's post |  #7
I have both, and both are great. I use the 7D when I want longer focal length or if I'm going somewhere where I want to use off camera flash but don't want to bring cybersyncs along, since the popup flash can trigger another flash. I think the video controls are more intuitive on the 5D2. It bugs me that the power button on the 7D is on the top.
I think I would miss the full frame more than the extra focal length. But if money was an issue, I wouldn't feel let down by the 7D.
Christina - Pittsburgh Wedding Photographer (external link)
Syncopated Pictures (external link)
http://christinamontem​urrophotography.com/bl​og/ (external link)
PeaceFire
Aug 17, 2010 10:07 |  #8
You guys are no help! :) OK, you were helpful. I am back to getting the 5DII. But now you're all making me want a 7D, too!!
stsva
Gallery: 45 photos
Aug 17, 2010 10:13 |  #9
PeaceFire wrote in post #10737403 (external link)
Best of both worlds (and the 7D's pixels are not "heinously noisy," despite what some (above) might say, although the 5Dii does have a high-iso image quality advantage over the 7D). :D
Some Canon stuff and a little bit of Yongnuo.
Member of the GIYF
Club and
HAMSTTR
٩ Breeders Club https://photography-on-the.net …=744235&highlig​ht=hamsttr Join today!
Image Editing OK
Michelle ­ Brooks ­ Photography
Joined Sep 2009
Aug 17, 2010 10:52 |  #10
gjl711 wrote in post #10735125 (external link)
Agree with the above. I have the 5dMKII and my husband has the 7D. Both are very useful & have their own particular niches. I covet my husband's 7D for it razor focus and he lusts after the expansiveness of my 5D shots. :lol: We shoot wedding & engagements mostly.
Michelle Brooks Photography (external link) | Flickr (external link) | Facebook (external link) | Twitter (external link)
PeaceFire
Aug 17, 2010 11:13 |  #11
Michelle Brooks Photography wrote in post #10737721 (external link)
Haha, NOT HELPFUL! :-P
nicksan
Man I Like to Fart
Aug 17, 2010 11:14 |  #12
I used to shoot with the 1DMKIII and 5DMKII. I sold the 1DMKIII and bought the 7D to hold me over until the MKIV came out. Owned the 7D for a month and sold it. Not saying it's not a good camera. Hardly the case. I just prefer 1.3x or FF bodies and IQ/noise control from them.
Of course I shoot Nikon cameras now, so it's probably a moot point, but I always liked the IQ of the 5DMKII and the AF is decent even in low light.
pcunite
Aug 17, 2010 11:16 |  #13
5DII and the 50 f1.2.
tdodd
Aug 17, 2010 11:19 |  #14
stsva wrote in post #10737446 (external link)
We are talking here about shooting at 6400 or 12800 ISO. Here is a full image and 100% crop from a 7D at 6400 ISO, no edits.
HTTP response: 404 | MIME changed to 'image/png' | Byte size: ZERO
I'd say that those 18 megapixels are pretty damned noisy at that ISO. If you think there is a genuine 18MP of valuable image data there then I am shocked. If you were to view at 50%, thus rendering your precious 18MP as a mere 4.5MP file it would be better, but still noisy and in need of cleaning up. I'm not saying the 7D is a bad performer, just that you don't get anything like a usable 18MP of resolution at higher ISOs. Is that a surprise? Of course not. But I'd prefer the output of 21 cleaner megapixels from a 5D2 to 18 noisier megapixels from a 7D. Sure, you'd need a bigger lens, gathering more light and spreading it over the wider sensor area, and that would all cost more. That's the price of admission to improved IQ. If IQ is what you care about when pushing the envelope then the 5D2 is the answer - IMHO.
I guess the question is - how big do you want to print and how much energy do you want to put into fine tuning your selective sharpening and noise reduction in your image files?
I've never tried the 7D at 12800 ISO so I don't know what the real world results are like at that level.
Anyway, I mean no harm by my choice of the word "heinously", but in my opinion the pixels are individually too poor in quality at 6400 ISO to be useful without some significant downsizing, and then you no longer have an 18MP image. I have no problem with the image quality, but the pixel quality is poor. I think that both the pixel quality and image quality from the 5D2 is superior.
I might add that my main use for the 7D is for shooting birds and other wildlife when I am focal length limited and trying to place a few extra pixels on my subject. With noise such as that at 6400 ISO, even 400 ISO on the 7D, you can easily see precious detail being eroded by noise. It's basically the saying about no free lunch. You can have clean and lacking detail (Nikon approach), or noisy and with apparent detail, but much of it false (Canon approach) when shooting at high ISO. If I'm in a position where I am not focal length limited I would much rather fill a larger sensor as much as possible and thus capture as much detail as I can with as little noise as possible. The only reason I used the 7D for that basketball shoot was to try it out. My preference would have been to use my 1D3, but I wanted to give the litle guy a chance. In future I would stick with the 1D3 for such things.
nicksan
Man I Like to Fart
Aug 17, 2010 12:11 |  #15
Good writeup Tim. I completely agree. That's how I felt about the 7D when I owned it for a month. 18MP's crammed in a 1.6x crop sensor is pretty much quantity over quality. Even at lower ISO (ISO200-400 for instance) I noticed noise, for example on blue skies.
12,135 views & 0 likes for this thread, 19 members have posted to it.
5DII or 7D
1315 guests, 178 members online
