Thread started 17 Aug 2010 (Tuesday) 06:44
7D picture styles.
Ross_Curtis
Aug 17, 2010 06:44 |  #1
I find with almost all my photos on my 7D I add a little saturation, contrast as well as sharpening.*
For ease of processing I mainly shoot in jpeg, unless I’m in a tricky situation and know it’s going to require major PP.
Is it a bad idea to do these adjustments in-camera with the user pictures styles?
6D | 24L II | 50MP | 85L II | 200L II | 16-35L F4 IS | Manfrotto 190CXPRO4 | Markings Q10 |
egordon99
Aug 17, 2010 07:37 |  #2
It's only "bad" if you get it wrong because you can't undo it if you shoot in JPG.
If you shoot raw, it's fine as the PictureStyle is just a "tag" to instruct DPP in how to initially process the raw data (as well as being used to create the embedded JPG preview that is shown on the LCD screen)
First off, your camera ONLY shoots RAW. When you select JPG, the camera takes the RAW data and pipes it into its on-board JPG processor to generate the JPG "image" to save to the card.
When you shoot RAW, the RAW "data" goes directly to the card and is not an image.
To generate an image, you use a RAW processor (software on your PC) which turns the data into a viewable image, much like the camera's JPG processor. The difference is that YOU have complete control over the image generation process. You can change the white balance, adjust the contrast/brightness/bl​ack point/etc....
So you can leave these decisions up to the camera's little processor (and hope it makes the right decisions since they are irreversible), or save the decisions for later where YOU have complete control over it.
753 views & 0 likes for this thread
7D picture styles.
Latest registered member is chergroovy1
2054 guests, 359 members online
