I see something through the viewfinder that looks like a piece of dust. Since I am seeing through the viewfinder does this mean it is on the mirror vs. the sensor?
Do things on the sensor show through the viewfinder
canonshooter Goldmember 2,242 posts Joined Aug 2005 Location: Arizona, USA More info | Aug 14, 2005 09:39 | #1 I see something through the viewfinder that looks like a piece of dust. Since I am seeing through the viewfinder does this mean it is on the mirror vs. the sensor? Jim
yellow_belly Member 142 posts Joined Mar 2004 More info | Aug 14, 2005 09:44 | #2 If you see dust in the viewfinder then it will probably be on the mirror or focus screen, if you see blobs on the actual image then it is on the sensor HTH
jfrancho Cream of the Crop 6,341 posts Joined Feb 2005 More info | Aug 14, 2005 09:54 | #3 If you see it on the viewfinder, then it cannot be on the sensor. However, that doesn't mean it won't show up in your pictures, or end up on the sensor. Use a blower, per your user manual frequently to keep the dust from accumulating.
RockStar Hatchling 4 posts Joined Aug 2005 More info | You might have something in the viewfinder itself. Try blowing out the viewfinder and see if that helps. Another thing you can try, if you want, is to take the lens off, look thru the viewfinder, and move the mirror with your finger. If the spots move, I would say they are on the mirror, if not, they are prop. on the focusing screan or in the viewfinder.
drewmk2 Senior Member 256 posts Joined Mar 2005 More info | Rock Star wrote: Another thing you can try, if you want, is to take the lens off, look thru the viewfinder, and move the mirror with your finger. If the spots move, I would say they are on the mirror, if not, they are prop. on the focusing screan or in the viewfinder. I hope you're being sarcastic?
jfrancho Cream of the Crop 6,341 posts Joined Feb 2005 More info | Rock Star wrote: Another thing you can try, if you want, is to take the lens off, look thru the viewfinder, and move the mirror with your finger. That is probably the worst advice I've seen in a long time.
RockStar Hatchling 4 posts Joined Aug 2005 More info | jfrancho wrote: That is probably the worst advice I've seen in a long time. That's why I said "if you want to".
ScottE Goldmember 3,179 posts Likes: 3 Joined Oct 2004 Location: Kelowna, Canada More info | jfrancho wrote: That is probably the worst advice I've seen in a long time. Maybe he has a job as a camera salesman. If he can't generate sales, at least he can find some work for the repair department.
jfrancho Cream of the Crop 6,341 posts Joined Feb 2005 More info | Aug 14, 2005 10:34 | #9 Then you should have stated, "If you want to possibly break your camera, try this..." How does that help? Your advice was just plain wreckless.
Jim_T Goldmember 3,312 posts Likes: 115 Joined Nov 2003 Location: Woodlands, MB, Canada More info | Aug 14, 2005 13:03 | #10 You ***won't*** see dust on the mirror.. It's too far away from the focusing screen for the eyepeice to focus on.. Same goes for dust on the lens.
pfogle Senior Member 581 posts Likes: 1 Joined Dec 2004 Location: Auckland NZ More info | Jim_T wrote: You ***won't*** see dust on the mirror.. It's too far away from the focusing screen for the eyepeice to focus on.. Same goes for dust on the lens. Any dust you can see clearly in the viewfinder will be on the focus screen.. Jim - spot on _______________
lomond Goldmember 2,366 posts Joined Apr 2004 Location: Ayrshire, Scotland More info | Jim_T wrote: Any dust you can see clearly in the viewfinder will be on the focus screen..
Cameron........My Images
booggerg Senior Member 460 posts Joined Aug 2004 Location: Chicago More info | Permanent bantake a brush to it and brush it off. 20D || EOS650 || 50 f/1.8 MKI || 17-40 f/4L || 70-200 f/4L || Sigma 35-135 f/3.5 || Yashica Electro 35 || Yashica Minister || Yashica Mat 124G || Hoga 120CFN || 420EX || Sekonic 306 || Panasonic DVX100 || Canon GL2
Blow the dust off the focusing screen with a rocket blower. 7D MKII ■ 10-22 ■ 15-85 ■ 28-135 ■ Σ 50-150 ■ 70-200 f4L ■ 100-400L ■ 580EX II
KennyG Goldmember 2,252 posts Likes: 1 Joined Aug 2003 Location: Leeds, UK More info | booggerg wrote: take a brush to it and brush it off. Do NOT use a brush on the focus screen. It is finely etched and even a brush can damage it. Only ever use a blower. Ken
| Latest registered member is Thunderstream 1028 guests, 112 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
