All in the title, but I am going to get a GND filter to play around. I am debating whether I should get a filter that is 1 stop at the top, or 2 stops.
Thoughts?
e02937 Goldmember 2,714 posts Joined Dec 2008 More info | Aug 18, 2010 07:28 | #1 All in the title, but I am going to get a GND filter to play around. I am debating whether I should get a filter that is 1 stop at the top, or 2 stops. Canon 7d
TaDa ...as cool as Perry 6,742 posts Likes: 3 Joined Feb 2008 Location: New York More info | Aug 18, 2010 07:33 | #2 I prefer 3 stop soft edge. 1 stop is relatively little difference, so if the sky is bright, your foreground will still be underexposed or the foreground will be fine and the sky will be blown out. Name is Peter and here is my gear:
Aug 18, 2010 07:35 | #3 Thanks for the help! Canon 7d
lerroy Senior Member 414 posts Likes: 3 Joined May 2010 Location: WA Desert Australia More info | Aug 18, 2010 09:37 | #4 lee / hitech / Singray JLB Photography Website
Needsnow Goldmember 1,814 posts Likes: 2 Joined Jan 2007 Location: Nebraska More info | Aug 18, 2010 10:00 | #5 I can't recommend this setup and this business enough http://www.2filter.com/prices/htpackages.html Canon EOS R
Aug 18, 2010 19:22 | #6 Thanks for the help, I'll give them a call tomorrow. Canon 7d
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Aug 18, 2010 19:31 | #7 They work better. You can slide the transition up and down to match your composition. Try that with a screw-on one. Jon
Needsnow Goldmember 1,814 posts Likes: 2 Joined Jan 2007 Location: Nebraska More info | Aug 18, 2010 19:35 | #8 I carry mine in this little pouch http://www.caselogic.com …l/index.cfm?modelid=65859 Canon EOS R
Aug 18, 2010 19:41 | #9 1)So in theory, you can keep buying Conkin P Adapter Rings and then keep using the same filters? Canon 7d
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Aug 18, 2010 19:50 | #10 1) Yes. Jon
Needsnow Goldmember 1,814 posts Likes: 2 Joined Jan 2007 Location: Nebraska More info | Aug 18, 2010 20:00 | #11 All you need to buy is a 77mm Cokin P ring and then just buy the step up adapters for the ring size. I think that would be a lot cheaper. Canon EOS R
TaDa ...as cool as Perry 6,742 posts Likes: 3 Joined Feb 2008 Location: New York More info | Aug 18, 2010 21:01 | #13 I hardly ever used my Cokin holder. I just found it more convenient to hold the GND in front of the lens since the exposures were relatively short. But yes, you can buy different size rings for your different size lenses. They just snap into the back of the cokin holder. Name is Peter and here is my gear:
Aug 18, 2010 21:19 | #14 Thanks for all the advice, so why are the numbered .3, .6, .9, 1.2. If I understand that's 1 stop, 2 stops, 3 stops, 4 stops respectively? Canon 7d
TaDa ...as cool as Perry 6,742 posts Likes: 3 Joined Feb 2008 Location: New York More info | Aug 19, 2010 06:31 | #15 Yes Name is Peter and here is my gear:
| Latest registered member was a spammer, and banned as such! 2882 guests, 183 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
