Is there a way to make the 7D take 3 pictures in a row after pressing the shutter button once? I can't seem to find how to do this for some reason.
Thanks ahead.
JLai81 Senior Member 736 posts Joined Oct 2009 Location: Ponte Vedra, FL More info | Aug 18, 2010 13:53 | #1 Is there a way to make the 7D take 3 pictures in a row after pressing the shutter button once? I can't seem to find how to do this for some reason.
Syntaxxor Member ![]() 243 posts Joined Dec 2009 Location: San Antonio, Texas More info | Aug 18, 2010 13:55 | #2 ....Can any digital do that? (I seriously don't know). ||Canon 50D||Canon Rebel XS|| EF-S 18-55MM IS||EF-S 55-250mm IS||EF 50mm 1.8 MK2||EF 28-135MM IS USM||430EX II||
Aug 18, 2010 13:59 | #3 Syntaxxor wrote in post #10745148 ![]() ....Can any digital do that? (I seriously don't know). I think you can do it with the self timer; but that's timed. Why not just hold the shutter for 3 shots? I wanted it for HDR shots. Figure it would be more stable than having to repress the button.
MT Stringer Goldmember ![]() 4,652 posts Likes: 6 Joined May 2006 Location: Channelview, Tx More info | Aug 18, 2010 14:00 | #4 Can't you set it up to bracket your shots, then fire a burst?
Aug 18, 2010 14:01 | #5 MT Stringer wrote in post #10745187 ![]() Can't you set it up to bracket your shots, then fire a burst? I guess my question is, can I get it to automatically burst 3 instead of physcially holding down the button until I hit 3 pictures.
yourdoinitwrong Goldmember ![]() 2,394 posts Joined Apr 2009 Location: Indiana More info | The self-timer on the 7D is part of the "Drive Mode" menu which is where you would select the low-speed continuous shooting as well so you can't have it do both (at least as far as I can figure out). I don't have a remote for mine but you might be able to put it in low-speed burst and then activate it that way. Using the shutter button though I'm pretty sure you have to keep it held down. 5D4 w/BG-E20, 24-105 f/4L, 70-200 f/2.8L IS II, 35 f/1.4L, 85 f/1.8, 100 f/2.8L IS Macro, Sigma 50 f/1.4
yourdoinitwrong Goldmember ![]() 2,394 posts Joined Apr 2009 Location: Indiana More info | If you are using it for HDR and use AEB you can put it on either timer in the Drive Mode menu and then it will take the three shots by itself when the timer counts down. 5D4 w/BG-E20, 24-105 f/4L, 70-200 f/2.8L IS II, 35 f/1.4L, 85 f/1.8, 100 f/2.8L IS Macro, Sigma 50 f/1.4
Aug 18, 2010 14:12 | #8 |
MT Stringer Goldmember ![]() 4,652 posts Likes: 6 Joined May 2006 Location: Channelview, Tx More info | Aug 18, 2010 14:13 | #9 A wireless trigger/receiver will work just fine.
JWright Planes, trains and ham radio... ![]() 18,399 posts Likes: 35 Joined Dec 2004 More info | JLai81 wrote in post #10745194 ![]() I guess my question is, can I get it to automatically burst 3 instead of physcially holding down the button until I hit 3 pictures. You should be able to do it if you use the self-timer. Set the amount of AEB you want in your menu, then set the drive to either the 2 sec or 10 sec timer and press the shutter. The camera should automatically fire the three bracketed shots and stop. John
stsva Cream of the Crop ![]() More info | Aug 18, 2010 14:15 | #11 If you are doing AEB and have it in high-speed continuous shooting mode, you only have to press the shutter button once and it will fire off the three shots so fast you'll barely have pressed the shutter button before it's done. Some Canon stuff and a little bit of Yongnuo.
Aug 18, 2010 14:18 | #12 Is there a way to get it to take multiple shots using self-timer without AEB? Say for use at a family group shot that I need to be in.
stsva Cream of the Crop ![]() More info | Aug 18, 2010 14:19 | #13 JLai81 wrote in post #10745280 ![]() Is there a way to get it to take multiple shots using self-timer without AEB? Say for use at a family group shot that I need to be in. I don't think so, but I could be wrong. Some Canon stuff and a little bit of Yongnuo.
yourdoinitwrong Goldmember ![]() 2,394 posts Joined Apr 2009 Location: Indiana More info | Aug 18, 2010 14:22 | #14 JLai81 wrote in post #10745280 ![]() Is there a way to get it to take multiple shots using self-timer without AEB? Say for use at a family group shot that I need to be in. If there is then I can't figure it out. The timers and continuous shooting selections are part of the same "Drive Mode" menu so you can't select both of them at the same time. You can just use AEB and vary the exposure by 1/3 which is small enough that a little PP can get it back to where you need it. 5D4 w/BG-E20, 24-105 f/4L, 70-200 f/2.8L IS II, 35 f/1.4L, 85 f/1.8, 100 f/2.8L IS Macro, Sigma 50 f/1.4
Aug 18, 2010 14:30 | #15 yourdoinitwrong wrote in post #10745309 ![]() If there is then I can't figure it out. The timers and continuous shooting selections are part of the same "Drive Mode" menu so you can't select both of them at the same time. You can just use AEB and vary the exposure by 1/3 which is small enough that a little PP can get it back to where you need it. Thanks for testing that out for me. Its wierd, but I coulda sworn I could take 3 shots continuously using self timer for my T1i. Not sure why they would take that out.
y 1600 |
Log in Not a member yet?
Latest registered member is Aidas.G 374 guests, 238 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 |
