let me know what you guys thinkk..
any suggestions and/or advice
1.
2.
3.
4.
deuce818 Senior Member 420 posts Likes: 6 Joined Dec 2008 Location: Burbank, CA More info | Aug 20, 2010 03:19 | #1 let me know what you guys thinkk.. 2. 3. 4. www.genuine-photography.com
PhotosGuy Cream of the Crop, R.I.P. More info | Aug 20, 2010 08:40 | #2 The light on it in #1 looks pretty good, but what did you like about the pole reflected in the window & side? See the links in my Sig & give them another shot. FrankC - 20D, RAW, Manual everything...
Aug 20, 2010 09:36 | #3 i agree with photosguy, the pole in #1 takes away from an otherwise nice shot, also in #3 looks to me like some fill flash was in order as the top of the ride was a bit dark, i especially like #2 and #4 the dramatic effect of the shadows in #4 on the white car and then the black car against the gray cement wall are well done.
Aug 21, 2010 01:19 | #4 thank u both, i agree with the pole reflection ,kinda throws it off www.genuine-photography.com
SJPHoto Senior Member 487 posts Joined May 2007 Location: Huntington Beach, CA More info | Aug 21, 2010 05:03 | #5 1) if you can re-shoot, try bringing car farther away from the background and crop for less road SJP WEBSITE
Aug 21, 2010 05:12 | #6 SJPHoto wrote in post #10761063 1) if you can re-shoot, try bringing car farther away from the background and crop for less road 2) get closer and use wider lens 3) I love night shots... careful with your flash. You can PS out the glare or add another side light to bring contrast to the top of the car. That part kinda blends in to the background. 4) Love the lines in this one. Easy with the post vignette and blur. I'd PS out that smudge on the back wall (right side of image) i thought having the car in the center for #1 would make it even, but ill take that into consideration next time. www.genuine-photography.com
PhotosGuy Cream of the Crop, R.I.P. More info | Aug 25, 2010 09:18 | #7 i thought having the car in the center for #1 would make it even, but ill take that into consideration next time. "Even" is static. "Uneven" is more dynamic. What is there about the pavement that makes it a better image? Load your image & see how it works in the Composition Adjuster. for #2, i am currently saving up for a wider angle lens, any suggestions? im using a crop body.. Sadly, the Kit lens is better than most people using it? FrankC - 20D, RAW, Manual everything...
iadubber Goldmember 1,453 posts Likes: 21 Joined May 2009 Location: Dubuque, IA More info | Aug 26, 2010 09:37 | #8 |
marcus769 Senior Member 642 posts Joined Oct 2007 Location: Minnesota More info | Aug 28, 2010 13:07 | #9 what lighting filters/things did you do in PP? I like them! The M3 is very nice! 7D, 40D, 28-135mm IS, 50mm 1.8 II, 100mm 2.8L, 70-200mm 2.8L IS, 580 ex II
feigenbaum Member 134 posts Joined Jul 2010 More info | Aug 29, 2010 00:33 | #10 4th love the lines and the car Hasselblad 500c/m ... 5D MARK 2 (ordered) ... 40D ... 17-40 L ... 35mm f/2 ... 70-200mm f/4 L ... plus other film equipment
SJPHoto Senior Member 487 posts Joined May 2007 Location: Huntington Beach, CA More info | Aug 29, 2010 02:34 | #11 What lens did you use? A good wide would be a 24mm. I have a 14mm but that's probally too wide for cars SJP WEBSITE
Sep 05, 2010 05:16 | #12 18-55mm www.genuine-photography.com
| Latest registered member was a spammer, and banned as such! 2875 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
