Thread started 20 Aug 2010 (Friday) 12:19
Problem with 60mm Macro setup
rraman
Joined Oct 2003
Aug 20, 2010 12:19 |  #1
Hello folks,
I am facing a problem with my setup that I hope to get some suggestions on...
I use Canon 60mm for a quite a bit of Macro photography in conjunction with 430EX flash and Lumiquest softbox (external link), however given the small size of the lens (and small working distance), the flash light falls beyond the subject (at least a part of it) :(
Can you suggest what my options are - I do want to keep the setup light :)
Thanks in advance!
Raman
5D Mark II | 40D | Canon 17-40mm f/4 L| Canon 50 mm f/1.8 | Canon 100mm macro f/2.8
www.theZenArt.com (external link)
ckckevin
Aug 20, 2010 12:30 |  #2
get the flash off camera. Having a second flash. Some sort of diffuser, Bounce the flash so that it can get light onto the subject. Make one of those ring flash converter from a normal flash.
Kevin life= learning
500D, Canon 10-22mm, Tamron 17-50mm 2.8, Canon 60 macro, Canon 85mm 1.8, Sigma 8mm 3.5, Sigma 30mm 1.4, Sigma 50-150mm 2.8, Kenko SP300 1.4x, efs extension tubes, 580EX, and lens that i don't like
mguffin
Gallery: 17 photos
Aug 20, 2010 12:31 |  #3
Yea, I think you need a ring flash...
Mike
Nikon D800 ~ Nikon D500
Sigma 35 f/1.4 DG ~ Nikkor 50 f/1.8G ~ Nikkor 85 f/1.8G ~ Nikkor 12-24 f/4 DX ~ Nikkor 17-55 f/2.8 DX ~ Nikkor 70-200 f/2.8 VR ~ Sigma 18-35 f/1.8 DC ~ Sigma 50-100 f/1.8 DC
rraman
Joined Oct 2003
Aug 20, 2010 15:49 |  #4
Thanks for the response folks!
I want to stick with regular flash instead of ring flash (has to do with difference in lighting they produce).
However I would like to hear thoughts on any compact bracket, or even snoot kind of diffuser that can help light reach the subject better and experience people may have with these.
Thanks again! :)
Raman
GJim
Aug 20, 2010 15:53 |  #5
Check this thread:
https://photography-on-the.net/forum/showthre​ad.php?t=142566
You should be able to get plenty of ideas for off-camera flash and diffusers.
G'Jim c):{- ... 2x 50D (Both Gripped), 2x 7D (Both Gripped), 2x 5D Mk II (One gripped), 1x 60D, assorted glass (10-800mm), sundry accoutrements.
The beginner clicks the shutter and says "Let's see what I got." ... The experienced photographer thinks "How can I capture what I see?"
My Photography: http://www.gjimphotogr​aphy.com (external link)
Martin ­ G.
Aug 20, 2010 22:26 |  #6
like mentionned already, get a flash bracket and all will be well.
6D & 70D
EF 24-105 L, EF 40mm, EF 85mm f1.8, EF 100mm L IS, MP-E 65
Macro Twin Flash MT-24EX, 430 EX II & 270 EX
2,248 views & 0 likes for this thread, 5 members have posted to it.
602 guests, 122 members online
