I've been frustrated with the quick releases of many of the camera straps. They always leave a long tail on the camera that seems to defeat the whole purpose of a quick release. There are times when I'm shooting, when I want the strap completely off the camera and I don't want the tails getting in the way.
Recently, Optech came out with their Adapt-its. Little plastic pieces that connect up to the strap mounts on camera bodies. I combined this with some small snap hooks from Berkley Point. I'm quite pleased with the outcome. Here's how it looks:
Connected to my Wapiti strap, although you could do the same with Upstrap, Optech etc...:
Showing it as it hangs:
Closeup of the Adapt-its and hook:
You can see that when you remove the strap, all that is left on the camera is just the little plastic Adapt-its. Very trim. You could run the Adapt-its in the other way so that they point up vertically and I may try that. I thought this might work better for how I use the camera.
I'm thinking it might be possible to have a handstrap coexist with this on the camera.
Adapt-its:
http://www.bhphotovideo.com …/OP_TECH_USA_1301322.html
Berkely Point:
http://www.berkeleypoint.com …ware/stainless_clips.html
J.
