Thread started 21 Aug 2010 (Saturday) 16:16
Suddenly my computer doesn't recognize my Pro9000
ncjohn
Aug 21, 2010 16:16 |  #1
When it rains, it pours!
Since I didn't like the way DPP was working with EasyPhotoPrint Pro, I was checking out other options, like printing from Irfanview or PS Elements. Somewhere in the process my printer driver apparently got screwed up. Now my computer says it can't recognize the "usb device" whenever I turn the printer on.
At first I thought it was a hardware problem so I plugged it into my other computer. That computer also said it didn't recognize the usb device, but I had never installed the Pro9000 software into that computer. When I installed the software, the printer worked fine. So the problem with my initial computer is the software.
I've uninstalled the Pro9000 driver and reinstalled it (twice) and that didn't fix the problem. I've also used system restore to restore the computer to the state it was in right before I installed the printer, then I reinstalled the software. That didn't fix the problem. I've gone into the hardware device manager and uninstalled the usb port that's having the problem (Interestingly, it calls it a "usb mass storage device" like it thinks it's a hard drive or something.) When I plug in the printer and turn it on, it recreates that port and shows it bad again.
The only other way I can think of to fix this is to uninstall ALL my Canon software because apparently there's something besides just the "driver" that's causing the problem. (Having a Canon scanner, 2 printers, and a DSLR means a LOT of Canon utilities, and when they install, they all intermingle in the Start menu and the Program Files folder!) Does anybody have any less painful ideas?
I'm using Windows XP sp2.
ChasP505
"brain damaged old guy"
Aug 21, 2010 18:13 |  #2
ncjohn wrote in post #10763121 (external link)
When it rains, it pours!...
...I'm using Windows XP sp2.
When I experience trouble like that, I remove the printer from the Printers and Faxes window, shut down the computer, pull the plug out of the wall, wait a few minutes, disconnect the printer and restart the computer. I then shut down the computer again and restart it.
I then turn on the printer and connect the USB cable. Hopefully it's OK now and Windows will rediscover the printer.
Any reason why you haven't gone to WinXP SP3?
Chas P
ncjohn
Aug 21, 2010 19:28 |  #3
ChasP505 wrote in post #10763527 (external link)
Well now, Charles, I've gotta say, that's the dumbest idea I've ever heard! On-off, on-off, on-off. It sounds a lot like, "Turn in circles 3 times and lick your left elbow!"
On the other hand... IT WORKED!!!bw! How in the world did you EVER come up with that?:p
1) When it first came out it was causing big problems.
2) All the security updates in sp3 are issued separately.
3) If it aint broke don't fix it.:)
Thanks a lot!
ChasP505
Aug 21, 2010 22:41 |  #4
ncjohn wrote in post #10763770 (external link)
I forgot to tell you do the Time Warp...
Chas P
1,739 views & 0 likes for this thread, 2 members have posted to it.
1059 guests, 103 members online
